Alright, alright. I'm a slacker. Guilty as charged. As Morpheus said, time is always against us.
So I looked at the Mastercam files you sent me Angus, and while they are pretty much correct there wasn't quite enough information to describe how to make the parts, mostly in terms of stock setup, but also the coolant port didn't look quite right; and the file for the key only covered milling the tabs, not how to make the entire part. So I went and created CAD models for both parts in order to have a complete representation instead of just one persons interpretation of how to cut out the parts. This way you could send the files to any machine shop, regardless of what software they use, and they could make them. The native files are Solidworks format but I also saved them as IGES files that any machine shop can handle. I'll email these to you shortly.
Now about the coolant port; I reshaped it for a couple reasons. One was to make it so that the stock D shaped thermostat housing gasket would fit better. The other reason was because the angled hole was actually cutting into the groove for the seal. While it would probably work ok that way it just didn't seem right. So I moved the flat surface over just a little to clear the groove. It makes the port slightly smaller but the cross sectional area is still much larger than the sum of the cross sectional areas of all the outlet ports on the thermostat housing. Which is the long way of saying it's plenty big enough.
Unfortunately, even with the reshaped port it's still going to be tricky to machine because of the way the hole is angled and how a typical 3 axis mill works. There are multiple ways to do it but the setup is not trivial. So I left it generally the way was and we'll have to see how it works.
I sent both models to my machinist friend to see what he would charge for these parts. Full price I'm certain will be quite expensive, but I've helped him out in the past so we'll see what we can work out. I also want to see if he has any suggestions for easier ways to make the coolant port.
The first shot at these would probably be done with whatever scrap is laying around just to check for fit, since I reverse engineered these from the mastercam files and also the dimensions posted earlier on in the thread.
Oh, and I almost forgot, there was another thing I was wondering about. I thought the countersinks for the mounting holes seemed a little shallow. The 3 smaller ones were at 0.25" and the 2 larger ones were at 0.29". I didn't change them but I thought I would at least mention it.
Here are some pictures of the solid models:
C|
