Results 1 to 11 of 11
Thread: I have a weird noise in engine bay
    Mar 2007
    I have a squeal under the hood of my car. It's not a typical loose/tight belt squeal, but more of a bad pulley. The thing is the noise is mild on a dry day, but if i go through a car wash or it rains or if the humid is high, the noise is horrible. also it started shortly after a water pump replacement. my question, could this be a bad pump or maybe a bad ac compressor, or something else. I can't pin point the source of the noise. Please help.
    Idaho
    Re: I have a weird noise in engine bay
    Sounds to be like the bearings in something are bad.
    Mar 2007
    ya I just wish I knew where to look?
    Idaho
    water pump
    ac pump
    power steering pump
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    i've got the same problem. i think it's my power steering,but, take off the timing belt covers get a long hose.on end too your ear move the other around in the bay while you run it. CAREFULLY! if it grabs the hose it could grab your fingers too or really screw somthing up. this is what i need to do as well but i'm lazy. it may be your t belt tensioner as well.
    Did you pry on the tensioner (or anything if you pulled hard enough) that'll damage bearings quick. been there done that. good luck! post what you find.
    Try it with the covers on first to see if you can find it that way. (duh) i like to keep an eye on things in there. too many broken belts and such
    use a piece of hose like a stethoscope and see if you can isolate where its coming from.
    it has been my experience that all these cars have bent waterpump pulleys (or pump shafts) so make sure the pulley isn't cutting into the lower timing cover. a slight wobble seems to be the norm in these cars
    you could also try removing the belts one at a time and running the engine to see if you find the culprit. you can drive all day without the p/s and a/c belts but only for about 1 minute without the waterpump/alternator belt.
    Timing belts don't usually make noise they just break. If the tensioner is bad the engine will have a raspy scraping noise when you run it with all the belts off.
    Eric
    Mar 2007
    thanks guys, I will be working on it tonight and post what I find.
    Jul 2007
    1988 Accord LXi
    Florida
    lol seems to be that time of the year. My accord had the same noise. I will be replacing the water pump soon before it fails. The sound wasnt happening all the time but at one point when it started making it I pulled to the side of the road for some quick diagnostics. Water pump pulley/bearings/rod. Water pump replacement here I come. I will be changing some belts at the same time.
    I had a squeak as well, and it turned out to be the water pump.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    timing belts can sometimes make a noise when they are getting on a bit.
    but they tend to make a rattley slappy sound
    how new are all the belts?
    Squirt some Wd-40 around, car running, you'll find the noise quick enough.
  1. weird noise
    By RAZR in forum 3geez Accords
    Last Post: 02-04-2012, 05:45 AM
  2. weird noise
    By poison2003 in forum 3geez Accords
    Last Post: 02-02-2011, 10:15 AM
  3. Weird Engine Noise
    By LXi87Accord in forum 3geez Accords
    Last Post: 02-05-2008, 07:12 PM
  4. weird noise
    By hondanutt in forum 3geez Accords
    Last Post: 08-27-2006, 10:18 AM
  5. weird noise
    By mattdx88 in forum Interior & Exterior Care
    Last Post: 08-19-2004, 07:41 PM
