Results 1 to 10 of 10
Thread: Lower ball joint broke at low speed...TG!
    LX User 1989accordaz's Avatar
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    1989 accord, AT.
    Just happen to stop at in intersection, proceeded to make a right turn and then something snapped on the driver's side wheel and then my steering got locked.
    So I get off the car, look at my wheel and is shifted away from the car, just the opposite direction from where I was steering at. My lower ball joint broke, thank God I was not going at high speed, otherwise I would have flipped like a hamburger on labor day weekend.
    So my driver's side half-shaft separated at the transmission end. Ripping the boot and dropping the bearings.
    So I got a new half-shaft and lower ball joint. I should probably replace the upper arm since the boot is ripped, but I think I'll just grease it and hope it holds until I get the money to replace it. Oh well.
    Any tips and pointers on putting everything back?
    Thanks!
    You are good...but I've seen better.
    1989 LX AT
    300,000
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Lower ball joint broke at low speed...TG!
    Probably a good idea to replace the UCA when you get a chance. Be sure to get a quality one with good bushings. When you replace the lower ball joint, check to make sure that the hole in the lower arm isn't egg-shaped from the nut being improperly tightened. Replace the LCA if the hole is deformed or you will risk breakage of the new joint. It is easiest to remove the knuckle, take it in, have the old joint pressed out, and the new pressed in. If you decide to try it yourself, be sure to remove the snap ring first. Where in Tucson are you?
    CARDONE SUCKS.
    LX User fogged's Avatar
    Jul 2007
    89 LXi Coupe 5spd
    Olathe Ks.
    Just be happy it was the lower and not the upper, those fuckers arent cheep. But the lower is an easy fix.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    depending on the model, you either have an arm with a press in joint or one where the joint is part of the arm.
    mine has the later
    would be worth investingating if the two are swapible
    talkin top arms
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    On mine, the upper ball joint is part of the arm. I am not gonna change it yet, I am gonna wait until I have a budget for both upper arms. Now, I haven't put it back together, because I was waiting until the machine shops are open on Monday because I can't press out the wheel hub. So it happens that one of the studs on the wheel that had the ball joint problem was broken off. So I am going to have that installed as well, since I have the steering knuckle off the car.
    LX-incredible, I am on the east side of town. Speedway/Harrison area.
    1989 LX AT
    300,000
    i replaced both my lower ball joints with moog ball joints. so far they are good....i had to get mine hammered out. its all ways a good idea to replace supension parts since you dont want them to take a dump at 70mph
    my mate did the exact same thing in his civic. was turning right but his left lower balljoint broke. Both of you guys are lucky it didnt come off at high speed that cd be real bad.
    Mar 2007
    Quote Originally Posted by fogged View Post
    tell me about it mine had to be replaced not too long after I got the car. I cant remeber the cost but it was lots of $$$ I had a shop do it too...
    Apr 2004
    1989 Accord LX
    Tucson, Arizona.
    Just to close this thread:
    When installing the halfshaft, I had to swap the new inboard CV joint with the old one, because the new one would just not go in and I was running out of patience. That was basically the only problem I had when putting everything back. The number of splines matched and everything, oh well. Doesn't matter, the old inboard cv joint is in perfect shape.
    I am going to replace the upper control arms and the ball joint for the front right oon. I don't want to temp fate. I guess that is why is called " preventive maintenance"
    FYI: I noticed, before my ball joint broke, that when my car shifted gears, I could feel my steering wheel "twitch" for a lack of a better word. It was noticeable at low speeds and even more at high speeds. By "twitch" I mean that it would shift to higher gear and the steering wheel would move right and then back very quickly, just a fraction of an inch or so. And now that I replaced the ball joint and the half axle the "twitch" is gone. So if this is happening to you, heads up, you may find this info useful.
    1989 LX AT
    300,000
    not trying to hijack this thread,but CAH read this!!!!! if you don't something about yours this is going to happen to you. it's not a matter of if,it's a matter of when. i've seen the pictures of your suspension. and you might not be so lucky.
  1. ball joint broke
    By dummass in forum 3geez Accords
    Last Post: 05-09-2012, 01:49 PM
  2. replacing the lower ball joint
    Last Post: 06-25-2007, 11:50 PM
  3. Lower Ball Joint
    By L3G10N in forum 3geez Accords
    Last Post: 07-09-2003, 04:03 AM
  4. lower ball joint problems
    By rotcjay in forum 3geez Accords
    Last Post: 04-18-2003, 04:03 PM
  5. Pics of lower ball joint? anyone?
    By winkie45 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-26-2003, 02:20 PM
