I have an aftermarket oil pan and i have replaced the seal 7 times already, and every single time it leaks in about the same spot. I have tried using sealant in that spot with no luck. I want to know, with the new Honda pan i am getting and Honda seal, where should i put the sealant. The shop manual says to put it in the corners on the block. So the block only, or somewheres else on the pan? Also do you guys recommend any type of sealant to use? I have RTV(silver) sealant.
