no more puff-puff-pass for this guy. lol
ya it is kinda hard to build stuff when all you can think about is chips,and popcorn. I'll keep on faricating though. damn ididn't get the memo...lol.j/k i dont mind a nice job every now and again..same goes for some of the bitching. it keeps me inline.
Here's a question that's been bugging me for a while. How do you get in and weld all the way around the pipe when the joint is right next to another pipe, or at the 3 o'clock and 9 o'clock positions of the 2-3 tubes on the flange? I've got a lot of experience on a MIG gun and I know that they can be pretty cumbersome in really tight spots like that. Also, the 4 inside faces right off of the collecter. How do you get in there to weld? I'd considered sneaking a 5/32 7018 rod in there and welding away, way narrower than the diffuser tip on the MIG. I know people do it, just not how.
I cut the collecter completely off of the header for my toyota, I chopped it both before and after and completely re-welded it, as the flange broke off and the metal between the 4 pipes had died. I just stuck it in the chop saw, and cut halfway through on each side, then flipped it and finished cutting from the other side. A bandsaw would have been nicer, but it worked. I just grabbed it in the vise, with a parallel under the narrow side to keep it flat.
your answer is to weld each piece separately. between the runner on 2-3 i welded runner 3 first slightly grinded the weld then welded runner 2 welding part of the wall of 2 to 3. there is not allot more you can do there.
on the collector you would weld in 2 half's also.
weld say 1-4 and 2-3 on the vice then weld the 2 half's together welding the outsides first, the you will weld the interior. you'll end up pooling the weld slightly in the center were the intersection is.
i was cold and for some reason they came out in black and white.
i call it old school pic's! lol
un-motivated!
3GR
Looks good but you really need to take some pics in better lighting conditions to see it really well.
wow looking great!
thats a hell of a turbo
that manifold looks awesome!! i want one!
thanks guys.i'll get better pics soon.
un-motivated!
3GR
Great work! Which way are you going to point the compressor outlet?
That compressor side looks nice and big I'm excited to see how your dyno graph will look.
un-motivated!
3GR
got them up kinda..lol
it still needs some cleaning and i need to figure out where i want to put the wastegate.
un-motivated!
3GR
looks good man, tight fit. got a kinda stupid question... are you not going to be running a filter?? doesnt seem like you have room for one...
race car ftw!lol
na no filter,ill put in a screen if i drive it on the street.
Originally Posted by 89turbo'ed
un-motivated!
3GR
doh, i should read the first posts lolol, sounds good man, just looking at all these turbo builds going on is makeing me want to get started on my own. cant wait to get my life going so i can
it's all good.pm me when you are ready, i'll build you a manifold.
un-motivated!
3GR
un-motivated!
3GR
super nice
