Results 1 to 6 of 6
Thread: fuel problem back
    bridgewater.NS Canada
    Exclamation fuel problem back
    well i thoght i had it fixed but its back,car stalled out on me and wouldn't start.had to get towed home,i hate my car.changed fuel pump ,cleaned filters still nothing.i checked for power to the pump and there is none,checked fuse its fine even changed fuel shut off with another one i had nothing. why the hell don't i have any power to the pump.can anyone help!
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: fuel problem back
    The relay will only actuate the pump with the engine running, when cranking, or for a few seconds after switching to run (II), so test it then. If it is indeed not getting power during those times, I would have a look at the ignition switch.
    CARDONE SUCKS.
    well last nite it acted up again it started to buck and shake.but i kept the gas on and turned the corner, hit a bump and it ran fine again.thats why i think it the harness to the tank.possibly a break in the wires.what do you think.
    cygnus x-1's Avatar
    Chicago area
    Yeah, sounds like a bad connection. As I said in your other thread, you pretty much just have to start checking wires until you find the problem.
    C|
    keep your same issues in the same thread, no need to start another one. It is a lot easier for us to keep up with the status of your problem that way
    there is a yet, third thread on this same thing import racer.. no wonder you think your posts are not being answered
    sorry bout that.
  1. Low Fuel Problem
    By Bassmastry101 in forum 3geez Accords
    Last Post: 03-31-2011, 08:30 PM
  2. Im back again with another problem!!!
    By badbobb in forum 2geez Accords
    Last Post: 09-17-2009, 02:59 PM
  3. fuel problem
    By import racer in forum Carburetor Tech
    Last Post: 11-10-2007, 03:42 PM
  4. Fuel problem
    By dillusion in forum 3geez Accords
    Last Post: 07-02-2006, 08:13 AM
  5. piggy back fuel controler
    By Ace in forum Performance
    Last Post: 09-26-2005, 08:41 AM
