Results 1 to 4 of 4
Thread: Car won't start....86 Accord carburated
    I'm getting gas and spark at the plugs. My car was running fine. The magnet under the stator has been broken in half for a month but the car has been running fine. I found a new magnet at the junkyard and decided to switch the broekn one for the one that's in tact. After switching the two magnets the car will not start. It cranks and when I gas and release the peddle it spits gas out of the carb. Before I changed the magnet I ran the car until warm and adjusted the idle control screw, the throttle stop screw and adjusting screw A. My Idle was then good. I hut the car and restarted it and it still worked great. I'm not sure if adjusting the idle had anything to do with it but I thought I'd mention it just in case. Any idea on how to get this thing started?
    Re: Car won't start....86 Accord carburated
    Also, I adjusted the air gap between the stator and reluctor already.
    logic would point to the last thing you messed with before the problem if it was ok before. So you may have disturbed the wires going to the pickup or to the ignitor, they can get brittle and have internal breaks.
    I did have 2 cracks in each of the igniter wires. I taped them up and reattached. The car still did not start up. I changed the timing at the distributor and it will now run. I get alot of backfire when I shut it off now though. I will have to time it with a light tomorrow.
  1. '85 accord (carburated) dies on startup every time
    By bugsplat in forum 3geez Accords
    Last Post: 09-11-2012, 03:50 PM
  2. Replies: 9
    Last Post: 07-21-2012, 06:23 AM
  3. Accord 89 Carburated
    By Spectro in forum Classic Honda Pics & Videos
    Last Post: 09-28-2009, 11:07 AM
  4. 89 accord won't idle (carburated)
    By dh89lx in forum Carburetor Tech
    Last Post: 02-22-2008, 05:09 PM
  5. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
