Alright.
I've got a 86 5MT LX with almost 280k on the factory clutch. Every gear but reverse is easy pie.
Reverse when the car has not warmed up is almost always 'crunch'. Even with the clutch to the floor. I just had the Honda dealer do the MTF so that's good. I'm not sure if this problem got better or worse after the change. Though all the forward gears seem to require much less clutch movement to engage them. So far, my solution has been to keep the car in reverse combined with the parking brake when I park. No grinding then. What gives?
