Results 1 to 4 of 4
Thread: prelude hybrid tranny
    3gmodifier's Avatar
    88 Accord LXi (sold) / B20A equipped 89 Accord Coupe (2.0Si replica) 2001 Prelude SH H23A Race Car, Track Orientated semi-built 2003 S2000, 2009 VW CC Turbo, 2007 Chevy Tahoe, and a damn 2005 Ford 500 lol!
    moreno valley, ca
    ok i know that the a2k5 tranny from the si lude will fit our a20a motors, but what are the internals like. because i have looking at the gear ratios and it seems like if you take the si lude tranny and swap the second gear from the 85 carb lude, you would have the fastest excelleration combo. and if you want a little more power out 5th gear compared to the stock a20a set up but not too much to ware your wasting gas, take the 5th gear from the carb lude. it's ratio is in betwee the accords and the si. i know all 3 trannies bolt on the a20 but are the internals interchangable. i would like to figure all this out and build a tranny that is designed for top end performance. i dont know just a thought.
    3gmodifier(aka)JDM WHORE!
    2ndGenGuy
    Guest
    Re: prelude hybrid tranny
    Top end performance? What exactly do you mean by that? Do you mean you want to get up to your cars top end quicker, or do you want to get to a higher top end? You'll have to consider the final drive ratios too, and choose one accordingly. The shorter gears will always result in the car feeling faster, and will give your car a better mechanical advantage, though may strangely make your car slower in things like the 1/4 mile.
    I have a Prelude tranny in my car, and ALL the gears are shorter due to the final drive. Even on the freeway at around 3400RPM my gas mileage hasn't been affected at all as far as I can tell. I did a drive down to California at around 90MPH which is about 4000RPM, and I still got ~28MPG. If I'm nice, I can still get 30-32MPG on my daily driving. I would guess that it's due to the engine not having to work as hard up hills, or when passing, etc. 5th gear has all the power that I need, making 4th pretty unnecessary on the freeway most of the time...
    if you want short gears you will need the 1st gen integra gear set. the final on that ones is 4.2 and the lx-i it is like 4.066 and on the carb the final is 3.8.
    cygnus x-1's Avatar
    Chicago area
    The ratios for the 2nd gen Preludes are as follows:
    '87 Si 5spd:
    1st: 3.181
    2nd: 1.842
    3rd: 1.250
    4th: 0.937
    5th: 0.771
    Rev: 3.000
    Final drive: 4.066
    '87 Dx 5spd:
    1st: 3.181
    2nd: 1.944
    3rd: 1.250
    4th: 0.933
    5th: 0.757
    Rev: 3.000
    Final drive: 3.875
    C|
  1. Hybrid Tranny!!
    By onliLX-i in forum Classic Honda Community Chat
    Last Post: 12-17-2007, 05:06 PM
  2. Teg Hybrid tranny w/ turbo??
    By Bglad420 in forum Performance
    Last Post: 04-10-2006, 05:14 PM
  3. Hybrid Tranny Gaskets
    By onliLX-i in forum 3geez Accords
    Last Post: 02-21-2006, 02:52 PM
  4. Replies: 3
    Last Post: 06-17-2003, 04:54 PM
  5. teg accord tranny hybrid success!!!!
    By Sean in forum Performance
    Last Post: 10-06-2002, 09:52 PM
