Results 1 to 6 of 6
Thread: Can i take off my choke
    Jan 2007
    I have a 89 accord lx carb....ever time i got to turn it on in the morining..it seems like the choke stays wide open and it revs up to like 3 thousand rpm for about 5 mins..till it warms up...the thing is is that it isnt cold here i live in houston texas so its always warm..so the question is ..can i just take the choke off? what does it do?.....any help will be Appreciated ..thanks.
    89 accord lx..carb
    259,000+ miles
    2ndGenGuy
    Guest
    Re: Can i take off my choke
    Quote Originally Posted by mark_salad_bar View Post
    Just give the gas pedal a good quick blip. It should come down to a reasonable level.
    should if it could, but most of the time these can't because the fast idle pull off is separate from the choke pull off.
    Some others here and myself have removed the entire choke and have no problems getting started even in high 20F degree weather. You would have to stay with the car for about a minute if you like to let it warm up while you go back inside.
    Nov 2002
    Ridin Dirty in New York
    doesnt sound like a great idea to me
    I tend to agree with that , on most any OTHER car. lol
    I do recommend looking into a search for that problem, it is worth addressing through "proper" measures.. there are a dozen or more things that cause that problem though. Check the most simple, like removing the air cleaner assy. and spraying down every thing with a good carb and choke spray and finish of with some wd40. Check for vacuum lines off or split open, or broke.
    Once you have done that, come back and post results, and we can see what the next step is.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    i removed my choke and, like roodoo2 said, ya gotta stay in the car and give it a lil gas to keep it goin for a minute (usually less), then just take your foot off the gas and if it will idle, then you can go back inside and wait for it to warm up or whatever. it doesnt get too cold here in oklahoma, otherwise i wouldnt have done it.
  1. choke
    By import racer in forum Carburetor Tech
    Last Post: 04-16-2009, 02:35 PM
  2. choke
    By leem in forum 3geez Accords
    Last Post: 07-05-2007, 06:37 PM
  3. Choke...
    By goldyaccord in forum Carburetor Tech
    Last Post: 12-14-2002, 01:26 PM
  4. weber manual choke or electric choke?
    By myaccord7 in forum Performance
    Last Post: 11-07-2002, 04:27 PM
  5. Adjusting choke/replacing choke??
    By stylus277 in forum Carburetor Tech
    Last Post: 08-21-2002, 08:51 AM
