Results 1 to 5 of 5
Thread: timing belt change- what else
    88 DX 5 sp
    Jackson, MS
    It's time to start planning for the timing belt change. What else should I plan to change while I'm at it?
    I figure motor mounts, water pump ($25 at NAPA?).
    Any suggestions welcome.
    Cheers,
    Roland
    Nov 2000
    Don't use an aftermarket water pump. I learned my lesson with a brand new (not rebuilt) water pump that had a bad bearing after only 18 months. I bought the pump at NAPA. You can get one for the same price from hondaautomotiveparts.com.
    I change the thermostat while I'm at it because you have the cooling system drained.
    Oct 2001
    87 Accord EX , 5spd , Manual
    use honda genuine timing belt !
    MIKE
    Jun 2002
    87 Accord DX Hatchback 5 Speed
    Cocoa Beach, Fl.
    the belt tensioner & spring.
    LXi User 1989se-i's Avatar
    89 Accord SE-i Coupe
    Jokelahoma
    How much was the water pump?
    Performance Modz: Short Ram Air Intake, Custom Exhaust w/o Cat & Resonator, Cherry Bomb Turbo Muffler, Accel Coil, Removed AC
    Other Modz: Clear Blinkers, Purple Calipers, Accord Emblem On Dash, Winking Headlights
  1. Need Help With Timing Belt Change in Bay Area
    By kk8 in forum 3geez Accords
    Last Post: 02-28-2011, 07:50 PM
  2. Timing belt change interval
    By w261w261 in forum 3geez Accords
    Last Post: 06-16-2010, 05:15 PM
  3. Non-Responsive Throttle after Timing belt Change
    By ChuChi in forum 3geez Accords
    Last Post: 10-26-2006, 02:50 PM
  4. timing belt change=performance gain?
    By Chrome_thangs in forum Performance
    Last Post: 05-17-2002, 11:50 PM
  5. timing belt: how difficult to change?
    By POS carb in forum 3geez Accords
    Last Post: 05-10-2002, 09:33 PM
