Results 1 to 13 of 13
Thread: will integra coilovers work.
    89 Honda Accord Lx
    Ontario, Canada
    its hard to find 89 accord coiovers, so would i be able to use 90 accord or 90 integra coilovers in my car
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    90 accord coliovers work i think someone on here has them
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: will integra coilovers work.
    90-97 sleave coilovers will work. Their's no reason why the teg coilover wouldn't work, all of them should allow you to use your original top strut assembly. Teg's use 2 bolt top mounts in the front.
    Now I d
    '89 ACCORD LX 4-DR.
    Honolulu, HI
    Jim, were you running coilovers in your car?
    Stock Carbed Motor, Stock Exhaust, 16x7" Rims, Full-Suspension, Slow As Hell, But Fun To Drive...
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    No, he had H&Rs all around, Konis rear and revalved Bilsten's (sp?) front
    Mike
    Central California
    No, but that was plan B. Since the revalved Bilsteins worked out so good I was either going to get B&G suspension springs(stiffer than the H&R's I was running) or stiffer than normal Ground-Controls.
    Now I d
    97 Dodge Neon
    Athens AL
    will 90 integra lowering springs work in our cars? my friend got coilovers and i think he still has his lowering springs,
    Central California
    The fronts will work, but the rear's won't. Our cars use 3" wide coil springs, civic's and tegs use 2 1/2" rear springs. The other thing is, if they drop a teg say 2", would they drop the same on our cars? I'm going to the junk yard today and I'm going to try and pull a 90-93 teg rear strut/spring assembly. What I really want is a rear 3rd gen strut assembly to compair it to, I don't have any as I sold them.
    I just thought of something. You could use those teg springs if you purshased a pair of rear coilover kits ($70 for 2) from opMotorsports, they use 2 1/2" springs, that would work.
    Now I d
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    Let us know. I remember reading that KYB makes a decent adjustable strut for the Integras for quite a bit less than the Konis. Having two (or three if you want to pay for revalving) choices for struts is pretty lame. If they matched up that would open up a few more options hopefully.
    Mike
    Central California
    Dang it I wasn't able to get to the junk yard today, I'll try tomarrow.
    Now I d
    Central California
    Oh well the integra that was at the junk yard is no more, I'll try another time.
    Now I d
    Justanothermike's Avatar
    88 LX-i coupe 91 LX coupe
    CA, San Francisco
    the struts and springs off of the 3rd gen integra and 5th and 6th gen civics will fit but will probably have problems. the rears are much shorter and if u use coilovers the perch will have to be all the way at the top. the fronts are much longer and the perch will have to be all the way at the bottom and u will run into botoming out problems. if u get the perfect length springs and adjustable perches then they may work, but u'll have to try a lot of combinations.
    Central California
    Thank you mike, I'm very gratefull for your post. We have a member that says he pulled 2nd gen teg struts off a junk yard car and he's running them on his car. I still question if the strut travel range's are where they are surposed to be doing that. I guess I need to break down and call Koni or Bilstein and get the factual demension's on both cars. I'm pretty sure the 2nd and 3rd gen's don't share aftermarket struts, I wonder why?
    So at this point I'm thinking about 2nd or 3rd gen teg struts, OpMotorsports basic springless coilover kit's and individual springs from ground-control. Picking the right length of spring would require some thought, but I think it can be done. Providing everything check's out, so far it's still in the maybe stage, keeping in mind the info mike brings to the subject.
  1. Replies: 16
    Last Post: 09-24-2012, 06:32 PM
  2. will these coilovers work?
    By jkool15 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-28-2007, 11:10 PM
  3. Would the e-brake cable off old integra work for 3g?
    By neoblue89lxi in forum 3geez Accords
    Last Post: 09-22-2003, 08:13 PM
  4. will 90-93 integra springs work on my 89??
    By bongler420 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-20-2002, 07:39 AM
  5. Will 90 Accord Coilovers work ?
    By GreenMachine in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-10-2002, 05:37 PM
