Results 1 to 13 of 13
Thread: Knocks from rear suspension
    Dear all!
    Please advise me what to do. I have accord 86 4D. Nice car. But i can`t understand why rear suspension works with some knocks?
    I have changed rear springs for a new ones, all sailentblocks and Levers. But knocking is still available! When somebody sit down on the rear seat -the knocks are gone! What is the reason of such suspension working i don`t understand. Perhaps my rear Shocks is bad?
    Also i have found that my ne springs have reduced upper spring coils. Is it normal? In manual it`s look like this coils shoud be at underneath.
    Please look for a photoes at ukranian Honda site, because i don`t understand yet how to attach photoes here. Thank you!
    http://honda.org.ua/forum/about28952.html
    Re: Knocks from rear suspension
    Check the rear ball joint. Usually they squeak when they are ready to go out but possibly yours are knocking instead. The ball joint has to be replaced with the whole upper control arm. The upper control arm also has a bushing, that could be the problem as well.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    The coils that are spaced closer should be on the bottom and should have rubber pieces glued to them:
    CARDONE SUCKS.
    Thank you pals! I have already replaced both ball joints - the sound is still remain. I see at yours photo that i have wrong assembled struts. Do you think that this could be a reason of knocks? Under the loading all knocks disappear.
    Sep 2006
    Tucson, AZ
    Could be. Might as well install them correctly, as they are pretty easy to get out of there. If you have some meat on your bones, you don't even need a spring compressor for the rear. I would also make sure the damper bushings are in good shape and that the lock nuts are good and tight.
    CARDONE SUCKS.
    LX-incredible! Please tell me, what is for this rubber pipes on the spring coils? Is they necessary?
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    rubber pipe? the rubber at the ends of the spring are just there for vibration suppresion. but you might have a rubber dust boot on there too
    I meant rubber pieced on the coils, on the bottom part of the spring. They reduce vibration or what for they are?
    Sep 2006
    Tucson, AZ
    I assume they're there to prevent the coils from banging on each other. Most aftermarket springs don't have them.
    CARDONE SUCKS.
    Quote Originally Posted by LX-incredible View Post
    yeah because aftermarket springs are much stiffer than stock
    Dear Advisers! Thank you all !!! I replaced my KYB`s for Tokiko and turn over springs! No more knocks and noises! Thank you for Help!
    Quote Originally Posted by Gres View Post
    yup tokico blues are not bad for the price. i took my subs out and no more rubbing problems on the rear.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Glad to hear that's all it took to fix the noises! Gotta love getting stuff fixed on the car!
  1. just bought sei rear suspension
    By Rich87HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-03-2004, 04:01 AM
  2. 87 Integra Rear Suspension?
    By DeathRat in forum 3geez Accords
    Last Post: 05-24-2004, 07:25 AM
  3. car knocks
    By Bioforge in forum EFI Tech
    Last Post: 03-12-2004, 11:09 PM
  4. Clunking in rear suspension
    By 300700'88lx-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-09-2004, 07:57 PM
  5. rear suspension problem
    By iowahawkeye01 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-11-2003, 06:25 AM
