I just rebuilt a carb from the junkyard for my 86 honda accord. Now that I'm hooking up the hoses to the rebuilt carb I've noticed that the A/C Idle Boost Controller Diaphragm Assembly is different. On the original there were 2 hoses. On the rebuild there is only one hose. As far as I can tell this is the only difference on the carb, inside or out. Can I just switch off the A/C Idle Boost Controller Diaphragm Assembly from one carb to another? As it stands now I have a spot to connect a vacuum hose but no hose to connect to it. I do have an A/C in case it matters to answer this question. Thanks.
