Results 1 to 7 of 7
Thread: Whats the part name of this part?
    Alright so last tuesday my car started to smoke a shit load from under the hood. I was on the freeway and once i hit traffic the smoked started to come out of the hood. The water temperature started to rise rapidly so i pulled over into the shoulder. It was dark and i couldn't see anything. I noticed water or some type of fluid on the floor and slowly dripping. The radiator wasn't full as well. I couldn't inspect the problem at night so i went ahead and called my parents to get me a AAA tow (free tow).
    So yesterday after working on my 240sx, i went ahead to diagnose the problem on my great daily driver. I top off the radiator with a 50/50 mix of coolant. I started her up and started idling high, as usual (is this normal 2500rpm then 2000 after a blip, 1500 after another small blip, then to 1000?). So im warming her up and i look under and i see its leaking a lot of fluid. The radiator cap was left open and the fluid was slowly going down, even with the thermostat still closed. I looked around and i noticed this hose was spewing out lots of fluid. The fluid was getting on the block and exhaust manifold/header causing it to smoke.
    right under carb near the firewall
    hose comming out of the coolant outlet on the head (possibly a type of heater hose?
    I felt around and the other end of the hose connects to right under the carb. Looks like an easy fix which i am capable of doing. Does anyone know what this hose is called and what it is used for exactly? Does anyone have the parts number for this hose?
    it kinda looks like this hose taken from partsamerica.com (kragen)
    If anyone can help me out, that would just be awesome!
    Re: Whats the part name of this part?
    Not sure about the correct molded hose but I'm sure and parts place can match up the size.I'm guesing 5/8" heater hose would be close. If its leaking by the buldge you could try and trim off the buldge and put a new clamp on it.
    You did good by not letting it over heat. Make sure when you add water the cars is running to let the cold and hot water mix and not shock the motor to much.
    i was thinking about just cutting it where the bulge ends and just re clamping it. i'll see, but just for future reference, does anyone know what this exact part is called and what the function of it is for?
    Quote Originally Posted by fr_pilot View Post
    Well first Look at this picture and Tell me which # hose is blown
    If it's #11 it allows coolant into the Intake Mani for the Thermo valves to work
    It's pretty Easy to replace and do to others having a Car die do to using non molded hoses, just spent the $10-20 to do it right
    It and the others can be found here:
    https://www.hondapartsdeals.com/hond...omponent=E++15
    yea its def #11
    19504-PH1-000 011 HOSE, BYPASS INLET - 1 $12.65 $9.33
    will the above part number correspond to honda's system?
    thanks a bunch, that was really helpful!
    Yes
    19504-PH1-000 Is the official Part number
  1. Replies: 12
    Last Post: 08-26-2011, 03:24 PM
  2. Whats This Part???
    By SILENT in forum 3geez Accords
    Last Post: 11-28-2008, 10:53 PM
  3. whats this part for?
    Last Post: 02-12-2008, 03:13 AM
  4. whats the JCwhitney part number for the CAI???
    By bobafett in forum Classic Honda Community Chat
    Last Post: 10-07-2005, 07:26 AM
  5. Hey! Whats that? Another part to install?!
    Last Post: 06-25-2005, 10:28 AM
