Results 1 to 9 of 9
Thread: Tach Jumping when starting
    1986 Honda Accord
    CANADA
    Exclamation Tach Jumping when starting
    1986 accord ex-i fuel inj originaly auto now standered, So i have a odd problem, my tach jumps up to 2500rpm -3000rpm when starting . Happens the most when its cold out(-18c) but can happen when its hot also, intermitante problem, i have tested the starter and its ok, leaning toward a distrubutor or timing problem, not really sure any help would be great thanks
    Drive It Like you stole it...
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Tach Jumping when starting
    Just the tach or the engine too? just tach i think dist.
    Nov 2002
    Ridin Dirty in New York
    most likely either distributor or coil. Listen to the engine when its running, if it sounds like you have a small rock kicking around in the distributor then you know its bad.
    shepherd79's Avatar
    Falling Waters, WV USA
    when that happens, it is 99.9% distributor with coil all together. It is a combination.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    time for a blaster 2 coil
    and a new honda cap and rotor
    Ichiban's Avatar
    North of You.
    Start the car in the dark and watch around the coil for arcing, or anywhere for that matter.
    ICHIBAN!
    "Now, even more better!"
    LX User Beanshonda55's Avatar
    Apr 2006
    1989/honda/accord/lxi
    lincoln, nebraska
    what would it mean if it is arcing.
    Ichiban's Avatar
    North of You.
    Burned out insulation on the wires, carbon tracking on the coil to a low voltage terminal or ground, carbon tracking on the distributer cap to ground, cracked distributer cap, basically any HT ignition fault to ground.
    ICHIBAN!
  1. Jumping Idle
    By SILENT in forum EFI Tech
    Last Post: 08-17-2008, 01:52 PM
  2. MSD tach adapter driving stock tach
    Last Post: 05-11-2008, 09:57 PM
  3. Eratic idle! and jumping tach
    By jerky_lxi in forum 3geez Accords
    Last Post: 07-04-2003, 05:36 AM
  4. Crazy tach when starting up
    By carotman in forum 3geez Accords
    Last Post: 06-02-2003, 09:52 PM
  5. tach is jumping all over the place
    By 89accordlxi in forum 3geez Accords
    Last Post: 01-29-2003, 07:50 PM
