Results 1 to 11 of 11
Thread: engine swap
    DX User fmh's Avatar
    1989 HONDA ACCORD LX
    Lawrenceville, Georgia
    engine swap
    hi guys I have an 1989 accord lx manual transmision and is has been my daily driver for the past four years. now Im going to replace the engine because it started leaking oil from everywhere. and getting and engine cost about the same as fix in the engine.
    I am trying to decide if i should replace with the same carb engine (A20A1) or just replace it with the fuel injection engine (A20A3) from the accord lxi.
    how hard it would be to put the fuel injection engine in, and is it worth the time and money to change from carb to fuel injection or i should just stay with the carb engine. would I need a new tranny?
    ps: both engines cost the same.
    the tranny in the car is in very good shape
    Re: engine swap
    the engines themselves are 100% swapable.. you just need to swap the fuel injected parts and wireing harness and etc etc... if you wanted you could buy the fuel injected engine and use your carb on it... there both almost identical engines... ust the intake and exhaust manifolds differ and what controles them.. and you can use your same transmition
    Feb 2007
    88 DX Hatchie
    Re: engine swap
    if you do the swap into a efi you'll also need to change the gas tank and add the fuel pressure regulator and fuel lines, the gas tanks from the carb and fuel injected are different.
    "The Original White" 88 DX Hatchback
    Mysterious Project Car
    www.myspace.com/tunerplayground
    You won't know what hit you
    Re: engine swap
    the fuel injected engine has a lil more compression and if its the same price might as well get the fuel injected engine and couple of extra ponnies.
    LX User GTRSkyline43's Avatar
    Jul 2007
    1987 Honda Accord Lx-i(Hatch)
    Hayward, Bay Area 510
    Re: engine swap
    Extra Ponies!!!!! Whoohoooo!!!
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: engine swap
    swapping to F.I. could be a pain in the bootay
    Re: engine swap
    swaping to EFI is way worth it imo most ppl that have carb cars wont to swap to efi cuz
    1. no more carb problems
    2. more power 122hp
    3. better mpg
    4. more dependable
    5. more tunable
    Re: engine swap
    2. more power 122hp
    3. better mpg
    4. more dependable
    5. more tunable
    1.Nothing wrong with carbs
    2.You will not get 122HP.
    3. Not always.
    4. Wrong, if cared for its dependable as hell.
    5. For a DD, you don't need to tune.
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: engine swap
    yea, plus we can remove the black box for a few extra ponies too.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Re: engine swap
    3. Not always.
    yea..people tend to get all scared of carbs because they dont know what to do with em
    Ichiban's Avatar
    North of You.
    Re: engine swap
    I know all about carbs, and I prefer the EFI system that monitors the engine and makes A/F ratio changes based on what's actually happening, not what should be happening at any given temperature or vacuum. Electric choke heaters? Come on. You ever hear of fuel injection freezing up in wet weather? Open your hood, see all that mess? It's an attempt to make up for the carburetors piss poor driveability, emissions and adaptive characteristics.
    You guys are just afraid of fuel injection.
    I actually have to agree with CAH on this one.
    Oh, and how does removing the black box give you more power? Maybe if the vacuum mess (which EFI minimizes) is causing a problem and power loss, then removing it might solve it. But so would maintaining the system that is there.
    ICHIBAN!
    "Now, even more better!"
  1. Replies: 3
    Last Post: 12-13-2008, 08:58 PM
  2. Engine Swap
    By 88' ACCORD LX-i in forum General Engine Swaps
    Last Post: 03-09-2004, 04:55 PM
  3. Engine Swap
    By RobbyKlotz in forum General Engine Swaps
    Last Post: 08-25-2003, 10:12 PM
  4. engine swap
    By easyryder in forum General Engine Swaps
    Last Post: 07-01-2003, 03:43 PM
  5. need pictures of engine bay to help me fix my problem with engine swap
    By jerky_lxi in forum Interior & Exterior Care
    Last Post: 06-06-2003, 08:43 PM
