1st post; been lurking for some time...
My son and I had a major electrical event with my 86 LXi last Friday night. While making a right turn out of Wal-Mart's parking lot, everything (dash, lights) went dark for a few seconds. I pulled off to the right, and then suddenly everything lit back up! Then I noticed all the smoke coming out from under the hood near the battery. We popped the hood, but not having a flashlight, nothing was immediately obvious (later I kicked myself for not disconnecting the battery then). My son and I then pushed it back into the parking lot (uphill, of course), and started to investigate. When we got the hood open again, this time there were flames on the firewall where the throttle cable goes through, and the cable itself was red-hot. We managed to get the flames out and disconnect the battery (glad I had my Leatherman…).
Long story short, after getting it home it became clear that the initial event was a short between the primary positive and negative battery cables.
The positive had been replaced - before my time - and a small amount of excess length had been looped forward so that it was resting on the negative cable, with the obvious inevitable outcome. For all the time I've spent under the hood of this thing, I'm surprised I didn't notice it until after it was too late. The battery shorting part I understand, but what I don't get is how the throttle cable became energized afterward; I mean that thing was glowing! The plastic over the metal sheathing was gone on both ends of the cable, and the plastic guide that twists into the firewall was completely gone - a molten, flaming, plastic mess.
While researching this issue here I came across one other thread that looks like the guy might have had a similar problem, as he referenced melting of parts of the cable assembly. Other than shorting this cable, I can't see any other way of causing the plastic stuff to melt - it just isn't that close to the really hot stuff.
I'm just hoping someone here can tell me how that cable got shorted in the first place so I can take some precautions to make sure it doesn't happen again. Thanks in advance for your help. This site has been invaluable to me (and the LXi).
Stan
