Page 7 of 39 FirstFirst ... 3456789101117 ... LastLast
Results 151 to 175 of 961
Thread: 87roach's 1987 S Hatch Build
  1. #151
    SEi User 86ccord's Avatar
    Middle Georgia USA
    Re: 87roach's 3g wip
    word.. looks good man!
    one day I'll return.
  2. #152
    SEi User knarg's Avatar
    '04 Forester 2.5XT
    Fort Collins, CO
    springs and struts!
  3. #153
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    springs and struts!
    Should be here tomorrow... waiting is killing me haha
    Andrew.
  4. #154
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Got this done today, it was a little tricky by myself.
    Goal for the end of the week is to have the gas tank/line, harness', heater crap, engine in. After that it's downhill. Also got my coilover's on the rear done, haven't got around to the front quite yet... it will have to wait till I get this major stuff done. I Didn't have the camera for the week so these are the only pics I have, anyway more to come.
    Anyone local want this carbed engine? heh
    Andrew.
  5. #155
    looks fun haha
  6. #156
    should blast that engine bay clean
  7. #157
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Well I didn't blast it clean but I sure scrubbed it!
    In this pic I have it cleaned, some paint touch up, the efi line run with new filter, new cv boot, and new throttle cable.
    Yesterday was a wicked day picked up these, they finally came in so I put them on today! (except the intake, the u-bend is my cai fresh from the powder coater's in semi-flat black)
    Here I did a little sway bar comparison since I had them all out.
    Andrew.
  8. #158
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    The rear:
    Pretty damn awesome, I'm stoked to drive this baby.
    Today I finished getting in the efi gas tank with all the lines and everything swapped over/connected up, so thats all done. After that I put the cabin harness in and tried to make sence of where things should go.. should be an interesting ordeal as there are different plugs/more connections then my hatch one. Oh well I will sort it out and make it work, more to come!
    Andrew.
  9. #159
    LX User Bones's Avatar
    Laurel Blue '89 LXi Sedan
    West Jefferson, OH (Columbus suburb)
    Man that engine bay looks awesome all cleaned out and touched up!! It's almost a shame to put an engine back in there because it would block the view.
    I'd like to get a set of them ST swaybars myself one of these days but I'd have to paint or powdercoat them before installing. Probably black to keep it stock looking. That green color they use is just butt ugly I think.
  10. #160
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    What kind of struts are those? They look pretty. heh
  11. #161
    what coilovers are those
  12. #162
    LXi User oldschool3g's Avatar
    1989/Honda/Accord LXI HATCH
    somewhere in cali
    those look hot man...ill eventually get some suspension techniques bars...keep up the good work
  13. #163
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Quote Originally Posted by Bones View Post
    Thanks man! It took me a while to clean.. but it was worth it haha. I actually really like the green, call me crazy but I do
    Skunk2 Pro S, I need to make the front work and check out the ride and then I will post about that.
    Quote Originally Posted by twhonza View Post
    Thanks man, you keep up the good work too. I'm looking forward to getting a bumper from you
    Andrew.
  14. #164
    sexy suspention!
    and what kinda car thos shocks made for?
  15. #165
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    This is so incredibly hawt. Props to you good sir!!
  16. #166
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    did that rear bar come with the endlinks you have? ..or did you have to pick those up separately?
    I'm going to wager a guess to say that you'll end up going back to the SE-i front bar. ...with a FWD (in an ultra-performance setup) the tendency it to tighten the snot out of the rear end (kudos on that rear bar) and keep the front fairly loose.
    Then again, it's just a matter of opinion too.
    My hat goes off to you for such an incredibly clean job you're doing on this. I know I've said it before, but it's worth repeating. This work is truly top-notch, and the attention to detail dwarfs anything else I have seen on anyone elses car on this site (maybe except only Dennis' hatch).
    Once this thing is done, I may have to make a trip to Canada just to see the damn thing.
    As for your skunk's, which application are those originally built for? Any idea on what the damper valving, and spring rates are on those? Anymore pics of them?
    -Mark D.
  17. #167
    geezus that looks nice!
  18. #168
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Thanks mark, I knew you would have something to say!
    The sway bars came with everything needed, as you can sorta see in the picture with the baggies. I did NOT buy anything seperate, it all came in the one big box. I will see how the front feels, I'm just stoked to drive at this point so any testing will have to happen later, haha.
    As for the skunks(90-93 teg) they are stiff! I only have the rears on right now, I had to put pieces together from both the accord and skunk to make it work. The fronts, so far I have had to cut off about 1/8 of the pinch fork(top) so that the bolt would line up properly. But it's too long and I need to do the top hat mod to get em to work(no vehicle is hard to run around and get things, I will pick up the bolts and stuff soon then get it all working). As for the rates the paper says springs are front "8kg/mm spring rate" and the rear is 6kg/mm spring rate" as for the damper I haven't found any numbers, all I have seen is "non-adjustable precision valving" so my best guess is that they are matched up to work well with the springs. Haven't been able to drive on them yet as I pretty much was off the road when I put them on.
    Anyway, once I get them all installed and what-not I should pull them out and show you guys what I did to make them work. As for today I got a bunch of the engine stuff swapped over, worked on the harness some more, and layed b-quiet on the trunk floor(so all thats left is the rest of the floor and driver's door).
    Thanks for the props, I think we will have to have a half way meet when you get those carbs on
    Andrew.
  19. #169
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Todays update:
    Got the passenger door harness in then proceded to the drivers door it took me longer then I had thought thats forsure. Had to take off the stuff from the parts door, install on my door and also covered it with bquiet.
    Also had to get a crankpully key from honda, $3 saved me a lot of headache, so I got that on and the alt. Next is to get the tranny on there and mounted.
    Andrew.
  20. #170
    w0000t
  21. #171
    Sweet!
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Well I lost half of last week due to vacation(oh well), so I should have more done but what can ya do.
    Anyway I ran out of bquiet but had enough to do where the floor heater goes(I did NOT want to take it out to have to put it on).
    The whole vent system has been cleaned out, and parts of my hatch system have been put in place(since im not using ac I used the funnel part the hatch had to get better flow).
    Here are some shots of the front skunk's, it took be forever to do the top hats, since I broke my vice and I did not have the proper size drill bits... oh and I don't have enough nuts so I can't attach the top yet, have to get that.
    Also had to cut the other pinch fork down to the same size since I COULDN'T get the thing off(rusted to the bushing once again), that was a slut. Both sides are on now so I just have to get the nuts for the top and it will be finished.
    Andrew.
  23. #173
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I ordered this generic short shifter for a 88 civic just to see how they would compare.
    Well its close but it's just not the same.
    I tried make it work but the ball is too big and wont fit into the housing where it's suppost to sit. I also got poly shift bushings installed. Tranny off the old engine and now I have to get it on the new one and plop it in.
    Andrew.
  24. #174
    Looking good! I noticed you don't have the rear splash guards on the rotors. I'd get some as I've heard that if water gets(puddle) on them you will lose braking power.
  25. #175
    woot woot
  1. Piter's 1987 Prelude BA2 build thread
    By piter in forum Classic Preludes
    Last Post: 02-08-2012, 03:13 AM
  2. King Peetis's 88 Hatch Build Thread
    By King Peetis in forum Project Central
    Last Post: 06-29-2011, 11:03 AM
  3. Mark's 89 Hatch Build Thread
    By markmdz89hatch in forum Project Central
    Last Post: 04-28-2011, 04:55 PM
  4. 87roach's 1987 S Hatch Build
    By 87roach in forum Classic Honda Pics & Videos
    Last Post: 09-20-2009, 09:44 AM
  5. Bglad420's 88 Hatch Build Thread
    By Bglad420 in forum Project Central
    Last Post: 02-25-2007, 02:54 PM
