Results 1 to 6 of 6
Thread: Anyone try experiment with different temperature thermostats?
    LXi User AC439's Avatar
    86 LXi
    FL
    Hi...I'm wondering if anyone has played with different temp thermostats to see if the gas mileage is better with the 195F thermostat?
    The Honda manual states two thermostats -180F and 195F. I'm currently using the Stant 180F thermostat. The temp gauge is about 30% (assuming midway between H and C is 50%). When the car is running for a while, it can gets up to 40%. I have used the Stant 195F thermostat before and the temp gauge can be at 50% but then rised to 80% while stop at the light or in very slow stop and go traffic.
    I kind of remember I was getting better gas mileage before but I'm not 100% certain. If anyone has experimented with this before, please share result here. Thanks. -AC
    Re: Anyone try experiment with different temperature thermostats?
    You will run richer with the colder stat. That will make more power depending on your driving style .
    The way you describe it though it sounds like your radiator is restricted or cooling fan temp switch is out of range.
    i just got honda OEM and it worksl fine.
    86 LXi
    FL
    I understand that cooler stat runs the engine richer. But my radiator and the cooling fan temp sw have both been replaced and makes no difference.
    I have also used OEM stat which runs the car even slightly cooler than the 180F stant thermostat.
    My question is:- Is there a practical noticable gas mileage difference between a 180F and a 195F thermostat? Has anyone put difference stat and notice gas mileage difference?
    shepherd79's Avatar
    Falling Waters, WV USA
    i had both 180 and 195 diff see any diff in gas mileage.
    OEM one gave me faster warm ups and my gas mileage actully went up by 1mpg but i could be driving like a granny.
    Your temp guage should never go above 50% really. Mine never never has even with a leaky top tank and the cap off, drives up and over 10,000 feet and extended 100 mph runs for more than 3 hours at a clip.
    As far as gas mileage the warmer a car runs the better the mileage on every car I have owned carb or fuel injection.
  1. engine temperature sensor and coolant temperature sensor
    Last Post: 03-29-2008, 02:16 PM
  2. Fail Safe vs Regular Thermostats
    By stat1K in forum 3geez Accords
    Last Post: 02-09-2007, 11:59 AM
  3. Little Experiment (check it out)
    By detroit313 in forum Classic Honda Community Chat
    Last Post: 05-02-2006, 05:11 PM
  4. going to experiment alittle.....
    By Vector in forum Performance
    Last Post: 04-06-2006, 07:08 AM
  5. all must go, 3g a past experiment
    By civteck in forum Trading Post
    Last Post: 09-21-2003, 03:30 PM
