I thought it would be pimp if i could wire up a switch to make a headlight wink while the lights were on. I'm sure someone has to have at least thought of this before, but I can't find a thread from someone who done it.
what would you have to do?
It seems that a lot of people have been playing with their Headlights currently.
To make one of your lights wink you would have to have some knowledge of electronics as you would prolly need to whip up a circuit, Unless you wanna do it the easy way and have a switch to turn one headlights motor off so only one pops up when u press the switch.
why wouldn't you do it that way? Then all you need is one switch and when you flip it you go from normal to wink..Unless you wanna do it the easy way and have a switch to turn one headlights motor off so only one pops up when u press the switch
My Aero had a problem with a winking headlight - one headlight motor was not working correctly.
Honda Accord Aerodeck Exclusive Edition '89 A20A3
Vw Jetta Mk1 Coupé '80
if someone will scan the headlight motor control diagram i will draw you circuit.
na i need something that shows all the motor control shit
