so xmas eve i was bored and decided to change my oil, since it has been 3-4 months and 4000 miles also i was gonna finally bleed my brakes...got done chaning my oil everything went good besides busting my pinkie on the concrete floor trying to loosen the oil pan drain plug...so then i bleed my brakes...i had 2 different brands and i did research and it said not to mix the 2 different brands so i bleed the brakes till there wasnt any...so i did that...open valve while the pedal was pushed down and closed then up with the pedal...topped off the master cylinder with new brakes fluids...did it again till the new fluid came out...after i was done test drove it...results was no brakes! i step on the pedal all the way down and nothing...but a small amount of brake force... i followed
https://www.3geez.com/forum/showthrea...ing+the+brakes
i told my brother and talked to my auto intruder and according to them its rear right, rear left, front left, front right...so imma go with that since the one above didnt help at all...
