Results 1 to 25 of 26
Thread: Removing Inner Door Panel
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    I'm planning on putting on a new passenger side door mirror and a new one of those plastic things that go up and down with the door locks. I've never taken the interior panel off of the door before and was wondering if there is anything I should watch out for.
    Also, if anyone has a Tuscany Taupe Metallic painted passenger side door mirror for a four-door SE-i I would be very interested in purchasing it from you.
    Re: Removing Inner Door Panel
    to remove it, remove all the screws in the way, put a flat head screw driver between the door panel start from the top, go down till you hit a clip, pry it out, around the whole door, once all the clips & screws are out, lift the door panel up and out of the door.
    oh dont forget to remove the plastic thing surrounding the door handle
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    You need to remove the window roller by taking out the clip from the back which is sort of shaped like a goldfish(work with me here), if you have a hook type screw driver it will be perfect or if not you can try to get a cheap slot and bend the end so it is shaped like an "(====)____\" if you get the idea, GL.
    It occurs to me now that what I said was only relative to the window roller(manual), everything else either unclips or unscrews but this can be tricky.
    nfs480's Avatar
    Rogers, MN, USA
    I understand everything except the door handle part. I understand what you mean by the shape of the screw driver, but nothing in my Haynes manual mentions anything about removing the door handle. Unfortunately my car is at the dealer for unrelated work so I can't go out and take a closer look at it but maybe when I get the chance to i'll understand what you mean.
    88 accord lx-i
    raliegh,nc
    you aint gotta remove no door handle just the one screw and the plastic piece arround the handle. I use a screwdriver to pry out the clips.
    for the top I stick the flathead through the door handle cutout and pry up carefully to detatch the top strip by the window. Its also held in by clips.
    nfs480's Avatar
    Rogers, MN, USA
    Thanks, that helps a lot!
    You missed one, in the vent. Unless your USDM accords dont have screws there?!?!
    SE-i Sedan 5 spd
    It's much easier to use something called a "panel removal tool" to pry things like the door panel apart. It looks like a big flat screwdriver with a bend at the end and a notch cut into the flat part. It gives you leverage when separating two parts, whereas a screwdriver increases the chance of damage. For instance, eventually you will have to clean out the rear sunroof drains, and to do this you have to take out the panels in the trunk. The panels are held on by "buttons". The panel tool can reach under the head of the button with its notch, and then the button pops right out. A screwdriver starts making a mess.
    Any auto parts store should have the panel tool.
    While you have the door panel off, you might consider lubricating the window lift mechanism. If you're ambitious, you can take out the driver's window switch (it gets most of the use) and sand off the contacts with a bit of sandpaper or a very small file. If the driver's window sometimes doesn't want to go up, it's usually either a dirty switch or more likely the window controller is starting to fail. If it goes completely, you won't be able to raise the window. It's a little white box inside the door. You can get another one from the yard or new from Honda for about $100.
    When putting the door panel back on, note the little bit of foam that Honda wrapped around the lock button. It's there to keep the button from rattling, so put it back in place.
    for those buttons, i use wire cutters to get them off, they leave no scratches or damage anything either
    SE-i Sedan 5 spd
    I guess if you've got a good supply of them you could do that. The panel tool pops them right out though, and you can then reuse them.
    Harbor freight has a tool that lets you take off clips easier. Now the name of it is impossible to recall.. But yeah its out there.
    i just pull on the door and it comes unclipped. Never have used a screwdriver.
    nfs480's Avatar
    Rogers, MN, USA
    I'm bringing this thread back because while I have removed my door panel before and replaced the plastic lock knob I still have not been able to find a mirror for my car. I'm planning on searching some junk yards later this week but it seems there aren't any around me. I was wondering if some of you who live near a pick-n-pull (closest one to me is in Illinois) could grab a brown se-i power door mirror for the passenger-side for me. If you can find one i'll gladly buy it from you. I've been searching all over ebay and other parts sites and it seems like they're impossible to find. I called Honda and checked Majestic's website and they are no longer available from them either.
    thats going to be really hard to find... you could just get 2 LX-i black ones or get a LX-i one and paint it to match
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    www.junkyarddog.com
    its the largest used part network on the web. if they cant find it for you, then youre probably SOL.
    nfs480's Avatar
    Rogers, MN, USA
    Quote Originally Posted by evil88accordLX View Post
    www.junkyarddog.com
    Thanks, I'll give that a shot.
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    OMG....You should put back the plastic wrap on the inside. you can feel a terrible breeze without it in the winter..i reused my old ones with some tooth paste works
    Toothpaste? I've always just shoved the plastic back behind the panel and hoped for the best. I should use duct tape, but if you are offering superior adhesion AND minty freshness, how can I go wrong???
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    lol. i bought some plastic sheeting and redid every hole in the door using hot glue. worked like a charm! just make sure to use high temp glue
    my doors are dynomatted so i didnt bother putinng the stock plastic back...its for like water doesnt ruin your door panels...but i just make sure the drain holes are not filled with junk
    Aug 2008
    1986 Honda Accord Hatchback
    Portland, Oregon
    Ok, so i don't mean to take this off topic, or revive a dead thread, but i was wondering how you take out the vent director in the door??? the one i have now is all chipped and broken and i have a new one but i need the old one out.... can i get it out without taking the door panel out or what???? and the trim around the door handle, does it just pop off after one screw or what?????
    i belive you just pry that out with a flat screw driver but i have not removed mine in ages so cant remember for sure
    May 2008
    "The Phoenix" '88 DX Hatch A20A1 5-Speed
    Santa Clara, CA
    could i hammer out a dent if i took my panel off i have a pretty decent door ding
    Sep 2009
    86 Accord LXi 5sp, 293k
    Montgomery, AL
    Thanks for the pics. My drivers door handle snapped yesterday. Thankfully I can still open it. I need to go to PAP to score another.
  1. How to remove door panel on 4 door LX?
    Last Post: 09-02-2006, 12:13 AM
  2. Removing the front inner fender panel liner thingy
    Last Post: 01-31-2006, 07:59 PM
  3. door panel
    By ninja2571 in forum Interior & Exterior Care
    Last Post: 01-29-2004, 01:55 PM
  4. Replies: 6
    Last Post: 12-30-2003, 01:16 PM
  5. WTB: door panel
    By jlaccord89lxi in forum Trading Post
    Last Post: 08-16-2003, 11:21 AM
