Results 1 to 25 of 26
Thread: tranny dump
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    tranny dump
    my tranny took a dump i think: when i put it in gear 1st-5th it does nothin i get off the clutch i wont engage brand new clutch and throwout bearing enybody kno whats wrong!!!!!!!! it just revs wont move
    Re: tranny dump
    do the other gears work?
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    i cant tell it wont engage at all they were working i had it in forth then i got back on the gas i went to N
    Re: tranny dump
    Thats gotta suk. Did it go with a bang or just die?! Does reverse work!?
    what does it do if u put it in gear without the clutch?? can u hear the gearbox makin any noises with the engine running and does the nosies change when your clutch pedal is pressed? Your new clutch might have been bad
    Re: tranny dump
    thats blows thats why i hold off on my clutch cuz im doing a rebuild on it. so shit like this does not happen.
    Re: tranny dump
    Well you know what they say, If your not breaking anything your not making enough power
    Re: tranny dump
    there had to be some kind of gut wrenching noise,your talking main input shaft broke or transaxle diff.... IF NOT
    then the clutch was out of adjustment the whole time, not fully enguaged, so now it is just slipping. It may be possible to get some adjustment so you have a little free play so you know it is not like you have your foot slightley in the pedal.
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    nun of the gears work it made no noise at all it just reved i thought the belt was broken cause the engine was just spinning
    LX User chriskatana's Avatar
    Jul 2003
    1989 CRX DX 1989 CRX Si 1990 CRX DX 1994 Toyota 4Runner
    Tuscaloosa, AL
    Re: tranny dump
    Can you put it in gear with the eingine runing and without pressing the clutch?
    Check the tranny, make sure that it is maked up to the engine correctly, you may have lost a bolt or tow and the trans is separating from the engine.
    Check your axles, if you broke an axle or one slipped out of the tranny, you will have the problem you describe.
    Check the cable, and the actuator at the tranny.. make sure something's not bound up..
    Is there any pressure on the clutch when you press it?
    Check the shiter linkage and torque rod... get under the car and make sure all that is still attached at the tranny and the shifter.
    Honestly sounds like you may have missed something when you put the clutch in.
    If not, then the input shaft broke, and you'd have major noise going on..
    Did you just replace the clutch disk and TO bearing or did you replace the pressure plate as well?
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: tranny dump
    when my tranny blew, it made all sorts of noise.
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    Quote Originally Posted by chriskatana View Post
    yes i can put it in gear without the clutch being pressed i will check the axals first the axal might be broken the pedal still have pressure and it made no noise at all
    Re: tranny dump
    You would hear something if an axle is at fault. when my CV broke it made a clatering noise lol
    i recon it has to be your clutch. Gearboxes just dont break silently
    Re: tranny dump
    good thread
    coupe if you can put it in gear, engine off, and then start it up in gear without pressing in the clutch... and still nothing ..no jump forward, no noises either.. it would be my guess an axle popped out, or broke or the transmission is not connected to the engine.
    carotman's Avatar
    Montreal South Shore
    Re: tranny dump
    Hmmm, you might have killed the differential
    cygnus x-1's Avatar
    Chicago area
    Re: tranny dump
    Since the clutch was the last thing you worked on I'm guessing it's a clutch problem. I think you're pretty much going to have to pull the trans and investigate.
    C|
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    i dont think its the clutch cause i wont engage im getting a prelude trans so no worried to much i think the trans is just broken i heard the driver side axel clicking a couple days ago that might be it
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    bump
    Re: tranny dump
    bump?? were waiting on you to start tearing it out, you have just about every possibilty mentioned here already except for why it happened.
    88 accord lx-i
    raliegh,nc
    Re: tranny dump
    geez,yank it already lol
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    ok i took it out and found out the ribbets came out the clutch so i wil be returning it back to clutchnet it just fell apart so i suppose that is the prob.
    Re: tranny dump
    a clutchnet disk failed on you?
    what pressure plate where you running?
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Re: tranny dump
    post pic's A.S.A.P
    Re: tranny dump
    yeah
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    im running a stage 1 green i will try to find the cords to my camera before i send it back
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: tranny dump
    update: i put the new clutch they sent me back in and works fine the tranny is not blown thank God but im still gion to go with the prelude trans ok now its supension time camber is so fuckin bad its like this / \ but hopefully i will fix it in a few weeks thanks everyone
  1. Open External dump??
    By Rendon LX-i in forum Forced Induction
    Last Post: 08-19-2008, 10:22 AM
  2. Hatch wiper, Dump it?
    By Ichiban in forum 2geez Accords
    Last Post: 10-07-2007, 10:09 AM
  3. winnipeg a big dump
    By 1ajs in forum Classic Honda Pics & Videos
    Last Post: 01-01-2007, 12:59 AM
  4. Time to dump the '88
    By Dncdesign in forum 3geez Accords
    Last Post: 06-26-2005, 02:01 PM
  5. so my brakes take a dump
    By 2drSE-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-22-2005, 03:29 PM
