Results 1 to 9 of 9
Thread: Body Work
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    Exclamation Body Work
    Yes I know i've been making a lot of threads lately but i've been planning out my year.
    I'm intending to have the extensive amounts of rust on my car repaired at a body shop (yes I know it's expensive but I just don't have any of the know-how to do it myself and I don't know anyone else who does). What should I look out for in a body shop and what major chains of body shops can you guys recommend. Also, what should I expect to pay. Picture below, sorry I can't get any closer up at this time.
    The other side isn't as bad, but the worst is the area below the doors.
    Re: Body Work
    it will probley be around 1200-2500
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: Body Work
    mine were about that bad. i was able to fix it pretty good with some bondo-glass.
    Re: Body Work
    The only chain body shop I know of right off hand is Maaco, and those are just like a Waffle House.. even though they have the same trucked in food, it is up to the cook to make it come out like it was intended. Most body shops are independent owned and operated, but they do share the same estimating software a lot of times.
    You can clean up the rust areas a little and let them dry out good, or blow them out with air, then spray this stuff called ONE STEP, it is basically aerosol paint that converts the surface rust to primer and neutralizes the rest. It has worked great for me. You can come back after it cures and use primer surfacer, or bondo glass (tiger hair) for the big holes if any, sand it smooth, repeat . until you do not see pits, then primer seal it before painting.
    Re: Body Work
    you will do better to find a shop that does car restoration work, they will have experience doing rust and panel repair,it might actually end up being cheaper ,because if they are experienced,they can probably make the missing pieces in house. places like maaco,they aren't set up to do this kind of repair, their usual buisness is getting overspray on taillights and automotive trim. check around,also talk to some hot rod guys who have gotten work done. if someone can do panel repair, it doesn't matter what kind of car it is. sometimes the smallest hole in the wall shops,have the best sheet metal guys.
    nfs480's Avatar
    Rogers, MN, USA
    Re: Body Work
    All right, there is an Abra Collision and Glass near here. It's a MN chain I think. Trying to find out if they're any good. I don't know of any restoration places off hand but i'll definitely search around for some.
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Re: Body Work
    If your going to be running around to different shops finding out estimates, post them up here.. I'm going to be looking into getting the same area repaired so it would be great to have an idea ahead of time.
    Re: Body Work
    let CAH fix it ROFL
    nfs480's Avatar
    Rogers, MN, USA
    Re: Body Work
    Sure thing, although I have a significant amount of rust on the panel below the doors which i'm sure will add significantly to the cost.
  1. body work
    By jigga89SEi in forum Interior & Exterior Care
    Last Post: 05-06-2008, 04:45 AM
  2. Body Work...
    By AccordNut in forum 3geez Accords
    Last Post: 12-27-2004, 06:00 PM
  3. does any body know if this will work
    By b20a86lude in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-06-2004, 11:10 AM
  4. How Much - Body Work
    By PsychoPaul in forum Classic Honda Community Chat
    Last Post: 01-30-2004, 11:34 AM
  5. More body work is done
    By pearldrop in forum Classic Honda Pics & Videos
    Last Post: 02-05-2003, 06:02 PM
