Results 1 to 7 of 7
Thread: Car overheating?
    LXi User johnwc723's Avatar
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    Car overheating?
    This has happened multiple times now to me driving on the highway now:
    My car will stall and refuse to start for at least an hour. When I do get it started if it hasn't been like two hours it will eventually die if idling or if I try to actually go forward with it.
    The first time it happened I put about half a gallon of radiator fluid in it thinking that might be the problem but then it happened again later.
    I replaced the thermostat thinking that might be the problem but I just boiled the old one (OEM w/ about 10k miles on it) to find out that it is still opening like it should.
    As far as what I have observed with the engine the upper radiator hose is pretty warm after running for awhile, the bottom one is quite cold and the thermostat housing is too hot to touch for more than a fraction of a second. The top of the radiator is pretty hot (not as hot as the thermostat housing) but if I touch the fins at all I find them to be pretty much air temperature (which is cold because its winter).
    I'm stumped to what is wrong with my car if it is overheating, perhaps the water pump? I'm not getting any sort of engine codes and my temperature gauge for the car is broken.
    Thanks for the help!
    Check out pictures of my car HERE
    "drop a 150 shot of NOS sticker on that bad boy and you can run 8s" -portugalfocus
    Re: Car overheating?
    Weird as if the thermostat does open then the upper hose should get hot. When was the last time the water pump was changed? Your radiator may also be clogged. I would replace the water pump and flush out the block and radiator.
    Also fix the temperature gauge, how do you know the engine is overheating?
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    I don't know if its overheating but I can't think of anything else that would cause those symptoms (if anyone else can?). I will probably just go and replace the water pump even though I'm gonna freeze the crap out of my hands in the process if you all think thats probably what it is...
    My guess would be the main relay if it isn't overheating.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    2x
    Easy fix.
    and
    FIX YOUR DAMN thermo gauge! THE most important gauge! screw gas or speed this is the life of your car
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    the temp gauge IS the most important... second to that is the fuel gauge imo.
    Feb 2003
    89 LX-i 5 speed
    Madison, WI
    haha yeah both my fuel gauge and temp gauge are broken... go figure
    I don't have access to a junk yard where I am right now to fix it;
    Based on the symptoms is it probably overheating? If so I will probably just replace the water pump for starters, I don't know if it has ever been replaced and the car has 160k on it.
  1. Overheating
    By MoDawG in forum 3geez Accords
    Last Post: 10-29-2007, 04:21 PM
  2. overheating still ...
    By gekko in forum 3geez Accords
    Last Post: 11-08-2003, 05:24 PM
  3. Still overheating, or so it says
    By mag_pbg in forum 3geez Accords
    Last Post: 11-05-2003, 07:56 PM
  4. car overheating
    By xaccordx89x in forum 3geez Accords
    Last Post: 08-26-2003, 05:59 PM
  5. Car is always overheating???
    By 86exi in forum 3geez Accords
    Last Post: 07-30-2002, 05:44 PM
