I'd like to extend a big congratulations to Legend_Master for winning 3geez's highest honor - Accord of the Year! We had a terrific list of AOM winners contending for the prize, and 3geez members chose Legend_Master's hatchback to stand above the rest. This is the second year in a row that a hatchback as won AOY.
Legend_Master
AOM: June 2007
Nominated by 2drSE-i
ENGINE
1991 B18a bottom end
Stock pistons bored .20 over
ARP head and rod bolts
Fully balanced/shot-peened and all parts were coated
New GSR/R Fuel pump and water pump
Lightened flywheel
GSR head Milled just a little
Cosmetic thin head gasket
STR Cam gears
AEBS intake manifold with stock GSR TB
Ebay Megan racing header modified with a 2.5 Collector
2.5" Pipeing all the way back to a vibrent Racing muffler.
SUSPENSION - FRONT
1. 89 LX-i hubs (must be 88-89 LX-i Hubs) with new bearing
2. 11" Acura Legend rotors Redrilled to 4x100 from a 1989 Acura Legend
3. 1998 Acura integra Type R Calipers (no bracket Required)
4. Full Prothane Poly Bushings for the Lower control arm and OEM for the rest
5. SS Steal braided brake lines all around
6. ARP extended Wheel studs (just because I wanted to)
7. Suspension Techniques 2.5" springs
8. 1990 Honda accord Full Bodied D2 Racing Coilover Sytem
9. Suspension Techniques front sway bar.
10. 1988 Prelude 35/40 prop valve
11. all ball joints and tie rod ends.
12. Ingalls Camber Correction Kit
13. EBC Brake pads
SUSPENSION - REAR
1. Sei Rear disk brake Convertion
2. 1989 Acura Legend Rear Calipers (they have a bigger pistons)
3. Drilled and slotted EBC rotors
4. EBC green stuff brake pads
5. Suspension Techniques rear sway bar
6. Lower Poly shock bushings
7. 1988 Honda Civic Full Bodied D2 Racing Coilover Sytem
EXTERIOR
88-89 Coupe Bumper
Integra Front Lip
Black Powder Coated Polished Lip Integra LS Wheels
INTERIOR
Removed Rear Seat
