Results 1 to 5 of 5
Thread: Idle speed at 1800 and will not go down!
    Awaiting Activation
    Jul 2002
    Virbius, my 1987 Honda Accord LX-i I got with no rust and only 92K miles!
    Independence MO
    Exclamation Idle speed at 1800 and will not go down!
    Ok, the idle speed of my 87 LX-i is stuck at 1800 RPM ever since I got the intake cleaned out last week and any attempt made to adjust it has no effect. The guy who looked into it for me was a Valvoine Oil Change guy and he said it might be an issue with the throttle body after he attempted to adjust it for me with no effect.
    Why would this be?
    Last edited by Reptile; 01-09-2008 at 01:23 PM. Reason: To explain the problem a little better.
    END OF LINE.
    Re: Idle speed at 1800 and will not go down!
    spray some throttle body cleaner...and check for vac leaks.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Vacuum leaks
    Also the valve at the back could be open leaking air in?
    shepherd79's Avatar
    Falling Waters, WV USA
    you have a vacuum leak somewhere.
    DX User justpassntime's Avatar
    Mar 2008
    87 Accord LXi, 87 Astro w/carb'd 350, 73 Ranchero
    Eastern Washington
    did they take apart the fast idle control valve? if this is adjusted so the stopper inside is too near the top it could cause this condition.
  1. Idle Speed
    By NoGeezsGap in forum EFI Tech
    Last Post: 06-06-2011, 08:59 PM
  2. idle speed jumps up and down
    By beeanner in forum 3geez Accords
    Last Post: 05-14-2010, 08:54 PM
  3. Sometimes won't start and 2K idle speed...
    By Josh89accord in forum EFI Tech
    Last Post: 09-10-2008, 04:13 AM
  4. '89' lxi EFI Idle speed
    Last Post: 10-13-2006, 08:42 PM
  5. Adjusting idle speed
    By jillindc in forum 3geez Accords
    Last Post: 08-22-2003, 08:59 PM
