so Ive got 2 turbos. Im changing directions again from my T3 42/60 to my larger T3/T4 60/63. This larger turbo has a dirrefent mounting flange so Ill have to pick up an adapter off the internet as opposed to having a new manifold made. The real questions is. Where to put the wastegate on the system for the different turbo. Also Ive got a tial 35mm wastegate. This should be large enough to get all the power from my turbo right?
Also if someone can walk me through injector sizing, and other little issues. Im planning 2 in charge pipes as thats the size of the inlets in my intercooler. The intercooler is a little undersized at 6x28x3 but is a name brand and might get some water injection at the track if temp get too high.
As everyone knows, available space under the hood is a little amis so if you can can help with that in mind it would be great. Mike
