Making a single wiper is quite easy. I will do this in steps so you can do it easily.
1. Remove both wipers. This is the time to paint them if u want. Inspect the wipers and get new one if you need to.
2. Re attach the drivers side arm (longer) to the passenger side mount at a 40 degree angle from the hood.
3. Tighten down the nut and it should work good. Play with the angle to get the most coverage.
I will get some pics later.
Please put this in the HOW TO section
Travis
