Results 1 to 12 of 12
Thread: Two odd sounds
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    Two odd sounds
    This thread is going to cover two completely different sounds coming from different places on the car, just figured I would keep things together to keep it simple.
    First, every so often when i'm driving i'll hear a "thoing" vibrating-like sound occur and i'll feel it through the floor. It sounds like something in the front suspension but I don't know what. It happens every couple of minutes and doesn't happen every time I hit a bump, but it usually happens more when i'm turning.
    Second, when I get to above about 30 mph I hear this light fast-paced clicking noise coming from under my dash that is continuous for the entire time i'm driving.
    Are these things to worry about and what could they be and how do I fix them?
    Apr 2007
    1988 Accord LX 5spd
    Re: Two odd sounds
    Mabey a strut spring. 2nd noise could be the speedometer or cable.
    nfs480's Avatar
    Rogers, MN, USA
    Re: Two odd sounds
    If it's the strut spring could this sound be indicative of something dangerous, or can I let it be for a while. Also, about how much would that be to fix, or is it something I can do myself?
    Apr 2007
    1988 Accord LX 5spd
    Re: Two odd sounds
    Depends on you're mechcanical ability tools and time.Of course too save time as far as the spring is concerned you could take it off and have a shop compress the spring too take it apart.For a fee,or rent the tool and do it yourself.
    If in fact that is the problem.You could get away without fixing it for awhile not a big concern the front end will sag and evetually blow out the shock if it isn't already shot.
    May 2006
    Re: Two odd sounds
    the front sound could also be a CV joint.. my car would even bounce when myne went out. look at the ruber boot on the CV housing on the side the sound comes from.
    DX User Purple_A20A1's Avatar
    Apr 2008
    '89 Honda Accord LX A20A1
    Raleigh, NC
    Re: Two odd sounds
    I'm having the same continuous clicking (almost grinding) sound under load... replaced the wheel bearings and axles and it is still there. I thought for sure it was going to be the axle, but now I'm thinking timing related issue. I'll keep you posted if I find the answer to this unusual problem.
    Re: Two odd sounds
    One thing to look at is brake pads and clips rubbing the rotor. The clips sometimes can rub the top part of the rotor and make a nasty noise. Brake dust shield could also rub making a terrible sound. They get bumped when working on the front end pretty easy.
    nfs480's Avatar
    Rogers, MN, USA
    Re: Two odd sounds
    Quote Originally Posted by Purple_A20A1 View Post
    Yeah, mine sounds like that but it usually only happens when I get above 30 mph. It also sounds like it's coming form in the dash so I think it's the speedo cable, at least in my case. I haven't gotten around to replacing it yet to see if it helps though. But yeah, definitely keep me posted just in case they do turn out to be the same.
    Idaho
    Re: Two odd sounds
    Quote Originally Posted by nfs480 View Post
    Just turn up your stereo.
    nfs480's Avatar
    Rogers, MN, USA
    Re: Two odd sounds
    lol, that's exactly what i've been doing. Now that i've gotten the amp replaced, before was the first time I had noticed it simply because the radio hadn't worked. Who knows how long this has been going on!
    Idaho
    Re: Two odd sounds
    Is the noise more annoying than concerning?
    nfs480's Avatar
    Rogers, MN, USA
    Re: Two odd sounds
    Yeah, I figure at worst the speedometer will stop working if it's the speedo cable. Then i'll just replace the cable and it will be no big deal.
  1. The Sounds Of MY 88
    Last Post: 08-10-2007, 02:00 PM
  2. That sounds bad...
    By 87_HaTcH in forum 3geez Accords
    Last Post: 06-17-2005, 05:39 PM
  3. sub sounds blown...but isn't
    By HaccordR89 in forum Interior & Exterior Care
    Last Post: 12-10-2003, 06:33 PM
  4. What Sounds System would you have
    By :D-LUDE in forum Interior & Exterior Care
    Last Post: 02-13-2003, 09:59 PM
  5. My Engine Sounds Like a Pig
    By Janiel in forum 3geez Accords
    Last Post: 01-13-2003, 10:21 AM
