I need a new one. I just wanted to find out if anyone new of a site or parts store that was the cheapest.
It would be cheaper to get one from the junkyard and just re-solder the connections. If you do however decide to just get a new one, try www.hondaautomotiveparts.com
anyone know the part number? i can't find it under rz-0028
I think this is it (#9). You might want to call their number and just confirm.
http://www.hondaautomotiveparts.com/...ROLLER+%281%29
I checked the link w261w261 gave, and #9 seems to be correct as is says RZ-0028 in parenthesis.
I would just heat up each connection, use a solder sucker, then resolder each joint. Itll work good as new
<And don't try to screw it back to the firewall, unless you're a contortionist. Just leave it hanging>
As a result of my struggles with the main relay, I bought a ratchet from Home Depot that, when you twist the handle, moves the socket drive. It would have made the removal and reinstallation of the relay much simpler for me. I think the tool cost $29.95.
