cygnus x-1
Even if you bored out to a 1.00mm over piston (.040") the difference in displacement would only be 48cc, about 2%. Not worth the bother.
Keep in mind, Honda only makes a 0.3mm (0.012") oversize piston. If it's needs any more than that you will have to use aftermarket pistons.
As for the rest, you won't find an after market intake for carbs, unless by some miracle you can find an older one used. If you use a downdraft carb you can use the stock intake, possibly modified some. Otherwise it's going to be custom. Consider getting a good 3 angle valve job with the rest of the work. That alone will help head flow more than anything else, except a big valve conversion.
C|
