i think you could probably use this (just like you can use an MSD BTM) but because our timing is not computer controlled we don't really know WHAT we are adjusting. so it would work, but you could never have a precision control over your timing.
without knowing the exact timing curve of the vac advance dizzy, and knowing that it is consistant, i would be hesitant to use this thing. especially if it has no way of knowing load. ie part throttle vs full throttle would probably merit different amount of timing modification. not sure it might have TPS input or MAP input, but still....
