Results 1 to 14 of 14
Thread: 89 Honda Accord loud popping sound
    Jan 2008
    1989 Custom Accord LXI Coupe
    Fresno
    for about 2 weeks now i cant get on my gas peddal and go . I have to ease onto the gas because my car makes a loud popping noise from under the hood. I thought it might have been the fuel injectors not putting out enough fuel to the engine causing the pistons to bang against the inside walls, Not true thank god . So today i decided to have my brother in law get on the gas a little and around 3,000 rpm the car made the sound the loud sound again i found out where its comming from and its the air intake. The throttle body i guess would be more correct but i took off the air filter and bam he reved it and my ear drum nearly exploaded. Does anyone know what this could be please help me I want to see my car get up and go once again.
    Sincerly Levon
    Re: 89 Honda Accord loud popping sound
    not sure, a valve or valve timing problem, or ignition or ignition timing.
    Vanilla Sky's Avatar
    1999 Penalty Box
    Could you descripe the popping noise? Sounds like a possible valve timing issue to me.
    Jan 2008
    Fresno
    it sounds like a backfire from a car exaust but from the air intake. Its not pushing air out but sucking it in and popping. Forgot to mention when i drive and try to get up it stumbles really bad on acceleration. If i ease on the gas it wont do it only a sudden thrust to the floor and bang bang here comes the outlaws with horses and all . You guys are the best for sure i have to put 3geez.com on my car some where, Thank you for the quick responses im watching a movie and looked at the screen to my amazment theres two replys within like 5 minutes thank you so much.
    1999 Penalty Box
    Yeah, a new post at night gets quick responses.
    https://www.3geez.com/forum/showthrea...ght=valve+lash
    That's the how-to on checking valve lash. While it won't show what's happening inside your motor, you can see if there are any issues with your valves from the top.
    You may also want to check your timing belt. There's a decent chance that it's slipped and you're either slapping the valves with your pistons or you're backfiring.
    The best manual is the one provided by Honda. It can be spendy, so one of our older members was so gracious as to scan the entire manual so that we could have a free digital archive. That is available here: https://www.3geez.com/forum/showthread.php?t=25137
    Jan 2008
    Fresno
    thanks so much your a great help i have the hynes repair manual but it doesnt tell me what the clearance should be for the car. Sounds kinda dumb but its true. I have to check the hyper links you posted i booked marked the one for the valve clearance just need to check the other
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    sounds like a miss fire to me
    take the big intake tube off from the throttle body or topoff the air cleaner for carb car and see if you can get it to fault again
    if it pops a flame out the carb/throttle body you have a big timing prob .
    could be the timing to far advanced and it firing before the inlet valve is not closed
    poss the cap, rotor ,leads and plugs all need replacing and timing set.
    if the valve clearances are to tite it wouldnt run well at all
    try 18 thou inlet and 20 thou exhaust
    these are generally not to far off for most engines altho they could be 12 inlet 16 ex.
    could be any of a dozen things eh dude
    go thru and check the ign system first off and work from there
    Blkblurr's Avatar
    Dayton, Ohio
    Yeah it sounds like a timing issue to me as well. Could also be a vavle clearance issue.
    all good information ^^^
    On the fuel side, fuel starvation makes cars backfire thru the intake/carb/throttle body
    In that case, fuel filters, puimp, contaminated fuel, stuck egr (on V6)
    Jan 2008
    Fresno
    great i now adjusted the valve to exaust .010 and intake .006 and guess what i tryed to start my car and its all screwed up i cant start it :P so tomarrow i need to mad scientist the valves again and see how i screwed up. aright guys thank you for the replies hopfully i can get it to start tomarrow and then check the egr and the fuel pump maybe im loosing some kind of pressure. This is good that im trying to adjust the valves any how because i was hearing a slight tapping from this area. (oh i figured it out the head is inside the car still and i was trying to line the gear up to the ground and so on so forth. ill get it right soon) wish me luck Thank you once again
    Sincerly Levon
    Jan 2008
    Fresno
    still cant figure out how to delete posts
    Did you put each cyl on it's tdc when you adjusted the appropriate tappets?
    Number one cyl is the one fartherest from the transmission.
    I adjust mine at .007 and .011. You really need some good light shining on that tappet clearence when you drag the feeler guage thru there, make sure you are holding the feeler gauge flat across the valve stem top and not at an angle. It should slide easliy but with slight drag, not enough to leave a mark really on the feeler guage in other words.
    Those other specs do not sound right at all for tappet adjustments.
    Valve lash specs are in the book and on the sticker on the inside of the hood. I would go by that first.
    Might have to verify that you have god compression numbers after you get the valves lashed correctly and the timing belt back on as well.
    Jan 2008
    Fresno
    The problem was that the #3 spark plug wire was off thanks guys for all the input..
    Levon
  1. popping popcorn sound in cat
    By Civic Accord Honda in forum EFI Tech
    Last Post: 08-02-2007, 12:16 AM
  2. Intermittent Popping Sound
    Last Post: 05-23-2007, 06:59 AM
  3. Very Loud Sound is it a Rod Bearing?
    By X-Lr8 in forum 3geez Accords
    Last Post: 12-23-2004, 06:41 PM
  4. Popping sound in front end
    By Dallas&SarahsAccord in forum Performance
    Last Post: 02-09-2004, 11:16 PM
  5. Loud pop sound??
    Last Post: 06-21-2002, 04:46 PM
