Results 1 to 10 of 10
Thread: so im starting my wire tucking...
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    like most of us here, i like the look of a cleaner engine bay, so ive decided that im going to tuck every last wire possible. for starters, ive already disconnected the entire harness, and since im going to be needing only certain parts of it, a majority of it will be discarded. as far as tucking in the drivers side, it seems fairly straight forward since im going to be ditching that entire side as i dont need any stock ECU control as im going megasquirt. the only problem i ran into when attempting to tuck that side was that my door couldnt swing far enough to actually get at that bolt, so that fender stays on for now, unlike the passenger side that came out after scratching my new paint a little.
    anyways, ive already gotten rid of the infamous black box of lines, and im going to just leave the plugs inside the fender or something for the time being. as far as the engine harness goes, HONDA IS GAY. its been a while since i last touched it, but i forgot that the harness stretches from one side of the bay, to the other freaken side and into the fuse box. anyways, ive already got it off the car, so now the fun begins of disecting the harness and shortening it to whatever length i need.
    anyways, asides from the alternator plugs, and the coolant temperature gauge plug, tach plug, oil pressure plug, and the starter ground, is there really any other wire that i may be needing?
    as far as my memory serves me, im ridding myself of the IAT, engine temp sensor, O2 sensors, IACV, injectors, TPS and probably a few other ones im forgetting about. as you can see, im getting rid of quite a few plugs, so ill be clearing out alot of room.
    now, does anyone know how to get rid of the fuse box? thats the one that im having troubles with right now since that is the only real suitable location for it
    Re: so im starting my wire tucking...
    moving the fuse box is not necessarily wire tucking is it? It has a cover and you can use loom to the wires coming out of it, you can make lexan or sheet metal sheaths for long stretches ,, hell even paint them the color of the inner fenders for stealthness.
    SEi User
    Jun 2005
    Edmonton AB
    moving the fuse box aids with the cleanliness look of the engine bay, and thats what i was aiming for
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Quote Originally Posted by newaccorddriver View Post
    where did the rest of the harness go to after you relocated the box?
    Well, there's still some some wires going out front to the: radiator, headlight, headlight motor, horn, turnsignals/parking light, sub engine wireharness, turn signal, battery/charge positive, map sensor.
    So you seperate the harness and a few wires going to the front will have to be made longer. Around 5-8 wires I think.
    Link to my 3geez garage
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    it would free up a lot of spce with that box gone
    3gmodifier's Avatar
    88 Accord LXi (sold) / B20A equipped 89 Accord Coupe (2.0Si replica) 2001 Prelude SH H23A Race Car, Track Orientated semi-built 2003 S2000, 2009 VW CC Turbo, 2007 Chevy Tahoe, and a damn 2005 Ford 500 lol!
    moreno valley, ca
    my fuse box is down ware the factory air/leave collector thing would go. as it was aleady said, some wires need to be seperated and modified a bit. i am all done with my tuck and yes it is worth it to get rid of EVERYTHING
    3gmodifier(aka)JDM WHORE!
    yah ive seen a18as wire tuck and it looks very clean in there. but also looks empty. i still havent decided what im going to do. with my engine bay its not the wires that are messy its the heater and radiator pipeing.
    and a/c & p/s hoses/pumps get in teh way of the cleanness also
    sucks how its all required
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    i just finished up my wire tuck looks dame sexy to and preety easy just need soldering skills
  1. Alternators: carb 3 wire efi 4 wire why?
    By AccordB20A in forum 3geez Accords
    Last Post: 02-08-2013, 06:02 PM
  2. Wire tucking is the sex: part 5
    Last Post: 08-31-2009, 10:37 PM
  3. Wire Tucking is the Sex
    Last Post: 04-20-2008, 06:45 PM
  4. Replies: 0
    Last Post: 12-30-2006, 09:10 PM
  5. power wire ground wire?
    By puleosei89 in forum Interior & Exterior Care
    Last Post: 04-10-2004, 03:27 PM
