Hello everyone,
I have an 87 Honda Accord and I am having a problem with the brakes.
First off I went to change the brake pads on the front of the car and I found (on the drivers side) the top pad looked great (very little wear seemed to be in great shape) however the bottom pad (the one on the inside of the drivers side rotor) was worn down over half.
The reason I went to change the pads is that the car was shaking when I used the brakes. I changed the rotors and the pads on the front (and will probably end up digging into the back brakes later).
Now I put on the new pads and drive it down the road. It feels like a caliper is sticking (and it is squealing) so I put it up on jack stands and try to roll the wheel. There is resistance as the wheel turns.
So I am guessing that it is a messed up caliper, I take of the tire today and it appears that something is leaking grease (caliper?).
I guess I should also say that there is no problem whatsoever with the passenger side wheel.
Questions,
How hard is it to take off the caliper? I have heard that it is 2 bolts (top and bottom), I removed the bottom bolt to change out the pads and that is not a problem but the top bolt has (what looks like) a cap on it. How can I get this cap off?
Does the stuff above seem to you to be a stuck caliper? The reason I ask is that it looks like the (new) pads have been subjected to some heat and one of the pads is starting to come off of the backing plate (not by much but you can see it). Another thing is that on one side the little piece of metal that you put the pad into seems to be bent, Do these come with the new caliper or can I pick them up at autozone (and what are they called)?
and finally should I replace both calipers at once (front drivers/passenger)? I am not having problems with the passenger side but I know that you want to replace the pads in pairs so I am wondering if I need to do so with the calipers as well?
Thanks for any help in advance,
Chris
