That was the main problem - SU's have piston/needle for fuel and plate for air.
A piston carb has no way of forcing the piston to close. If you tip an SU upside down the piston can open w/o the throttle rotor moving.
This means that when you suddenly close the throttle, The engine will still have a vacuum acting on the piston and fuel which won't necessarily force it to close, meaning that fuel could still be sucked in (without air, potentially causing fuel pooling)
For a blowthrough setup you have to remember the fuel being pulled through the jet relies on airflow AND vaccum to pull it through, not just airflow as such. E.g You have massive airflow at 10psi but you have to remember that there is now 10psi pushing back on the fuel jet, so you would need over 10psi fro ANY fuel to flow into the carb.
BTW - What was your original SN name and also Rendon LX-i's?
As you probabally know I havn't been on this forum for a while since I found CB7Tuner.
I'm originally from Wellsford, but living in Auckland now.
I take it you've visted CB7Tuner before? That setup is more commonly know as the DSM setup. Its what I have on my CB Accord.
