Results 1 to 8 of 8
Thread: Running lean
    Apr 2007
    1988 Accord LX 5spd
    Running lean
    I've had this problem for sometime now car runs decent around town.But getting into it 2000rpms up it dies off struggling too get speed. The recent emission test I passed but had a question about my readings CO%= 0.01 limit 1.10
    HC%=116 limit 275
    NO%=3590 limit 3600
    At 1746 RPM
    14.4%Dilution.
    Anything look High or wrong besides the NO% reading.
    I,ve checked the timing it's in spec. EGR valve works correctly. Also,checked for vaccum leaks.
    Any ideas? Oh my fuel pressure is 2.5psi at the pump and at the carb.Have not done the fuel capacity test for volume at 1 min.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Running lean
    https://www.3geez.com/forum/showthread.php?t=46572
    got there for idle and emission help.
    Other then that you might want to check your booster venturies.
    https://www.3geez.com/forum/showthread.php?t=48568
    Apr 2007
    1988 Accord LX 5spd
    Re: Running lean
    The only thing I have not checked is compression and Air/Fuel set screw.Also,I still have the problem with the car dieing after the first start.But after the second attempt it starts and bobbles up too 2400rpm fast idle.Another problem.This just started.
    Apr 2007
    1988 Accord LX 5spd
    Re: Running lean
    Update, did a compression test.Here's the data.
    #1 #2#3#4 all 135psi. No wonder it has a lack of power running lean. And occasionally smokes on warm up. Don't know why I waited so long mabey afraid too confirm my suspicions.
    Just for referrence I think Minimum psi =142 and Max =171 according too the Haynes manual for what it's worth.
    Re: Running lean
    how many miles does the car have....try that engine restore thing...a 6 buck investment would not hurt.
    Apr 2007
    1988 Accord LX 5spd
    Re: Running lean
    The car has 206thousand miles. I might just do that but, I'm going too do another compression test just too ease my concious. I think the gauge is of slightly off. I'll use another gauge just too be sure. Also, I have too fix my choke heater.
    SEi User 86ccord's Avatar
    Middle Georgia USA
    Re: Running lean
    dirty fuel filter maybe? cause i had a problem similar to that, my car would spit and sputter and jerk, do all kinds of things.. and i changed all of my fuel filters, my distributor cap, and aloso my sparkplug and spark plug wires, and soon enough it was back to normal, so just some things to think about.. OH also i ran some sea foam to clean out my engine, so yeah some things to think about..
    one day I'll return.
    Apr 2007
    1988 Accord LX 5spd
    Re: Running lean
    I'ts all been done.
  1. Replies: 13
    Last Post: 12-11-2011, 12:40 AM
  2. Lean on 1/8 to 1/4 throttle.
    By Inferno in forum Carburetor Tech
    Last Post: 10-28-2010, 12:16 AM
  3. b20a lean
    By A18A in forum 3geez Accords
    Last Post: 09-29-2010, 03:33 AM
  4. rich or lean mixture
    By shepherd79 in forum 3geez Accords
    Last Post: 12-31-2003, 08:27 PM
  5. Running Lean
    By Kevin in forum EFI Tech
    Last Post: 01-26-2003, 10:52 AM
