I got the quaife unit because it is advertised as a 2 way not the stock 1 or 1.5 way. Everything seems ok considering all I can do is benchtest it as the engine still isnt in the car. The shifter seems a little tough from the center position over to the 5th/reverse section so im not sure if something needs to spin to mesh or it just needs to settle. Im also only using the rubber gromet outside the linkages not the leverages of the shifter itself. I know rob had issues the 1st time he had his apart also.
