Results 1 to 17 of 17
Thread: B20A Manual Transmission Part numbers (B2K5 and F2K5)
    carotman's Avatar
    Montreal South Shore
    Hi 3geezers
    Finding parts for the JDM B20A is somewhat easy since the engine shares most of it's components with the USDM B20A5. However, the B20A manual transmission is unique and doesn't have any match on other Honda products.
    I made a list of ALL the transmission parts with their corresponding part numbers. I labeled the parts that had a direct match with a USDM part number. This means you can go directly to the Honda dealer (or Acura in some cases) and order the parts. This also includes the part number of non available parts so you can order them overseas in you want.
    I'm happy to say that every bearing (except 1) are available in North America. I have that particular bearing here and will try to find a match for it in the near future.
    Unfortunately, some parts do not have a matching USDM number. However, this doesn't mean another USDM part will not fit. The gears and syncros could be matched with other trannies I'm pretty sure. After all, the D and B series engines share some tranny components even if they do not have the same part numbers.
    Here are the exploded view diagrams with a part number list (listed in the same order as torringtonhondaparts.com )
    MT CLUTCH HOUSING
    MT CLUTCH RELEASE
    MT COUNTERSHAFT
    MT DIFFERENTIAL GEAR
    MT MAINSHAFT
    MT SHIFT ARM ROD
    MT SHIFT FORK
    MT TRANSMISSION HOUSING
    I know the diagrams are really big but it's the best way to have the most details you can. If you find them too big, just resize them. These diagrams are not available anywhere else on the internet to my knowlegde so, again, 3geez.com is the pioneer :D. These are the actual B20A Tranny diagrams from Honda.
    If you need more diagrams like this on the B20A, let me know and I'll see what I can do.
    carotman's Avatar
    Sorry, the server on which they were hosted is now dead.... (I will try and fix this later)
    If you need a specific part number, just email me.
    Edit:
    It's back online... anyway, if it's dead, just ask me.
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: B20A Manual Transmission Part numbers (B2K5 and F2K5)
    Sorry to post here, delete my post if you want,
    my question is, dos A20 clutch kit fit the b20?
    My Build Thread
    the pressure plate MIGHT if its the recessed flywheel type, but the clutch disk wont as the input shaft has more splines on the B20A
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Quote Originally Posted by Tomisimo View Post
    Nope it won't fit. I tried it already. The B20A clutch kit it bigger than the A20. The flywheel is as well
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Why I ask is because I've just recently bout a resurfaced fly wheel and clutch kit for my A20. But It got me thinking of going B20 last few days. Than I need to sell this kit asap if I'm going B20..
    My Build Thread
    if you use a b18 box i think you can use the a20 clutch, but being where you are located all b20as are manual anyways i think
    Jan 2003
    1986 prelude
    charlotte nc
    does anyone kbow how i can find or where to find a jdm catoalog for like parts like diagrams of the ba1 AND B20A MODEL
    LX User OldSchool86's Avatar
    Sep 2008
    1986 Accord Lx 5Speed
    A T L a n t a, GA
    I'm going to be doing a B20 swap in my "86 Lx". It's a carb car and I'm not sure what all i'll need other than the harness and ECU. Can anyone help?
    search :) if the search works
    Jan 2003
    1986 prelude
    charlotte nc
    got a tiny ? ok so if i replace my clack top b20a tranny qith all the seals is it going to be the same as b20a5
    hammer3rd's Avatar
    Sep 2008
    2000 Powerstroke 1988 LXI sedan
    Claremont
    Just got my tranny in and was looking around to see what was going on. Well all of carotmans exploded views will not open. I was going to see if any 5th gear would fit the F2k5. From what I have read I like all the gearing but 5th. Not knocking the trans cause I got it at a sweet deal but even the .771 of the 87 Si lude would be a little better.
    Mike C in NC USA
    carotman's Avatar
    Views are fixed. My host was down.
    hammer3rd's Avatar
    Sep 2008
    Claremont
    Thanks carot didnt know what to think. You are the man and your stuff goes down some of us panic.
    Mike C in NC USA
    Mar 2007
    Very helpful, thank you
    Apr 2010
    i need a help here pls, can we install 2nd gen prelude jdm si b20a manual gearbox into jdm b20a accord ca3? because the ca3 is using automatic gearbox,wanna convert to manual,is it possible to use the lude gearbox? pls help me out =(
    yup
  1. Replies: 6
    Last Post: 05-27-2012, 11:13 PM
  2. WTB B2K5/F2K5 Transmission
    By OldSchool86 in forum Wanted
    Last Post: 04-07-2009, 10:12 AM
  3. F2K5 vs B2K5 Transmission Ratio
    By carotman in forum JDM B18A / B20A Swap Tech
    Last Post: 08-22-2008, 11:57 AM
  4. B20A Manual Transmission part list
    Last Post: 05-13-2005, 06:59 AM
  5. [Engine & Transmission] B20A / B18A Transmission Numbers (auto and manual)
    By carotman in forum Frequently Asked Questions
    Last Post: 02-09-2004, 06:30 PM
