Results 1 to 8 of 8
Thread: final drive swap questions for b2k5
    Washington
    so I was playing on a gear calculator site tommy posted up and was debating if its worth the effort to try to swap the b20a final drive with a civic cx/vx type final drive. I remember looking for the LSD and reading a post saying the diff itself fits almost all non vtec transmissions. Thsi means the final drive gear will bolt on the diff. Ill need to know if the pinion gear will swap from either tranny and if the cx/vx gear is intrchangable on the b2k5 shaft.
    Does anyone have access to a honda manual or infomation telling me overall internal races of the gears or stack shaft in this case before I buy a transmission I cant use. thanks
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Re: final drive swap questions for b2k5
    You need a countershaft that fits the differential ring gear you want to use. You cannot change the gear on the countershaft.
    Did you check out the tranny section in shopmanual 62se320.pdf ? Also there's gear ratios on page 3-16 and various tranny specs on page 3-6.
    Gear ratios for F2K5 transmission KX area in shopmanual 62se321.pdf page 6-18
    Link to my 3geez garage
    Washington
    yes I saw that. I wasnt sure if the f2k5 would work because noone has said they have one but tommy. I tried the a20a3 stacks in the b2k5 case and found that the bearings on the top of the stacks on the a20a3 wont fit the b2k5 housing and the shafts are different sizes so you cant swap bearings over from one to the other.
    Jan 2003
    Denmark/Europe
    No I wouldnt have thought the A20 ones would work either. And the gears themselves wont swap between the shafts either.
    Accord of the Year - 2008
    TWOLOUDNPROUD's Avatar
    May 2003
    Quote Originally Posted by thegreatdane View Post
    There is no 6-18 in the shopmanual 62se321.pdf.
    http://www.pauldesign.ru/honda/shopmanual/62se321.pdf
    May 2003
    Bump
    Jan 2003
    Denmark/Europe
    page 3-18
    May 2003
    so it go's like this
    B2K5 ratios are:
    1st 3.166 40.68MPH
    2nd 1.857 69.35MPH
    3rd 1.259 102.3MPH
    4th 0.967 133.19MPH
    5th 0.794 !62.2MPH
    Reverse 3.000
    Final reduction 4.066
    And
    F2K5 ratios are:
    1st 3.166 40.68MPH
    2nd 1.772 72.68MPH
    3rd 1.185 108.68MPH
    4th 0.967 133.19MPH
    5th 0.794 162.2MPH
    Reverse 3.000
    Tire size used for both 205/40/17
    So this is the difference between the B2K5 and the F2K5.
  1. FS: Final Drive and Limited Slip
    By dloper in forum For Sale
    Last Post: 10-26-2011, 09:51 AM
  2. Need LX final drive!!!
    By hammer3rd in forum Wanted
    Last Post: 01-22-2011, 11:06 AM
  3. final drive ratio?
    By accordlxi2.0 in forum Classic Honda Community Chat
    Last Post: 08-19-2007, 12:27 AM
  4. Need help with alternate Final Drive
    By Richard Floyd in forum Performance
    Last Post: 05-10-2005, 05:27 PM
  5. Final Tranny swap questions!!!!
    By sporkHSP in forum General Engine Swaps
    Last Post: 07-23-2004, 09:30 AM
