Alright, back to the point of this post...
I Played around with the car today, it'll go into any gear without me touching the clutch, but it grinds if i try and put it in reverse.... And If my foot is on the clutch, there isn't any movement on the speedo, but if I let out the clutch the speedo bounces a bit, not high or anything, just bounces under the 0. Now that wining noise when i put it in reverse and let out the clutch is accually quite loud if you stick your head under the hood and listen.... something in that tranny is definitly slightly grinding or spinning....
I couldn't put fluid in the tranny... I had a spout..but I'll need some hose, a long flexable funnel or a pump to fill it up...
umm... I think thats all I have for you guys... Definitly want some help with this
