So.. I've almost got my accord workin' the way I want it to. The thing is I still have problems and I'm kind of out of ideas. Help? Suggestions?
When I first start my car it runs around 1000RPM, then it likes to idle around 800-900ish RPM. As soon as I push the brakes, and shift to reserve the RPM drops down to 600-700RPMs causing the car to shake. After going 60MPH down an empty road and stop the car THEN will it start to idle around 900RPM. (Does that mean I have to warm up the car everytime I start the car??)
Though it gets worse, I'm not sure what is going on inside the engine because it feels like its misfiring or something. I hear like a popping sound ocassionally, (which is why I'm thinking it's misfiring?) I hate this popping sound, I can even feel it through my foot when I'm either braking or accelerating. It's annoying as stepping on a rock or something. I always thought it was my tires or suspension just being like crap.
So I start the car and put my hand on the engine block, well on the cap so I don't burn myself. :P But anyway, I put my hand and I definately feel something unusual. So something is going on.
Now more than ever I'm getting 12 blinks from the ECU. It's the EGR, Just when I finally went through the trouble of fixing broken off vacuum connectors and plugging them in it still doesn't work properly I guess.
I think the EGR and the idling is connected in someway but I'm just lost. Oh and last question, (I'm thinking there isn't enough oil) how much oil is suppose to show up on the oil dip stick? Is it suppose to reach the first dot or the second dot? Maybe I'm running around with little oil *gasp*
Then I gotta fix the fuel sensor, it never tells me that I'm nearly empty. D: I also have to fix the side door sensor. Turns out the black switch just doesn't spring all the way back. Then I'm going to replace the carpet, it's somewhat torn. So yeah... Still lots of things to do before I start thinking about CAI's and header/exhuast and stuff. :p Anyway, comments/questions/suggestions appreciated.
