Results 1 to 8 of 8
Thread: Welding ?
    Dec 2003
    Millington, TN
    Welding ?
    Need to do some body repair. But I need info when welding on body. I'm disconnecting negative battery cable and the ECU cable.
    Is there anything else that I should be aware of.
    Thanks.
    Phil
    Re: Welding ?
    If you are doing some serious hot work you may want to clear any plastics and insulation behind your work area. Keep spray paint cans (aerosols) away from possible slag , wear clothes approved for welding, no polyester, no butane lighters in your pocket (I can vouch for that one !!!)
    You have the electronic part purdy much covered.
    LX User Lil Mike's Avatar
    Toronto, Ontario
    Re: Welding ?
    cover any glass with cardboard or something to keep the splatter away from it. little metal balls will melt into the glass and ruin your glass
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Re: Welding ?
    Quote Originally Posted by Lil Mike View Post
    yea..the asshole who was filling the holes in my trunklid let some slag hit the window...i almsot tore the dudes head off
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    Re: Welding ?
    and make sure that your welder is set up for welding thin metal. too many amps or too much heat and you can warp or even put holes in the sheet metal.
    Re: Welding ?
    ahh yes, dont forget the glass !!! Also any grinding you do, be careful about it landing on the paint up on top of the car, moisture gets to it and causes lil tiny rust spots that do NOT come off.
    Dec 2003
    Millington, TN
    Re: Welding ?
    I'll be using ER70S-6 0.23 wire and mostly tacking so as not to build to much heat.
    Thanks all,
    Phil
    Re: Welding ?
    Yeah .023 is a must. I think if you keep the ground close to your work the electrical part will be fine.
  1. Welding Question
    By 88Sleeper in forum Classic Honda Community Chat
    Last Post: 09-12-2012, 08:05 AM
  2. DIY Exhaust without welding for $150
    By Swap_File in forum Performance
    Last Post: 07-22-2008, 11:37 PM
  3. The Welding Thread
    By Ichiban in forum 2geez Accords
    Last Post: 04-16-2008, 06:09 PM
  4. welding question
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 01-01-2008, 08:57 PM
  5. welding up a new exhaust
    Last Post: 08-25-2006, 12:36 PM
