Results 1 to 11 of 11
Thread: Does anybody know the resistance curves for our CLT and AIT sensors?
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    Hey I am looking for the specs on the resistance curves for our stock coolant temperature sensors (the ones the ECU sees, not the fan switches) and our stock air intake temperature sensor.
    I checked my shitty chilton, and didn't find it. Also checked my nice real FSM, and couldn't find it in there either.
    If anybody knows these off the top of their head that would be great!
    Thanks,
    Chris
    Re: Does anybody know the resistance curves for our CLT and AIT sensors?
    I think your acronyms are off but here you go:
    IAT- intake air temp
    32 degrees F- 5.0 Kohms to 5.2
    140 degrees F- 500 ohm to 520
    plus or miinus 10% is acceptable
    ECT- coolant temp to ECU
    32 degrees F 5.0 K ohms to 5.2
    195 degrees F .2 K ohm to .4 K ohm
    plus or minus 10% is acceptable
    Both sensors also get reference voltage
    bobafett's Avatar
    Longview, WA
    sorry about the acronyms. I am going to be installing my engine management soon and those are the acronyms they used so thats what's in my brain lol. The system uses GM sensors with the following specs:
    70 degrees F: 3300 ohms
    180 degrees F: 350 ohms
    It looks like they do not match very closely. According to my chart for my TEC-GT, at 39 F there is supposed to be 7500 ohms, and at 68 F, there is supposed to be 3400 ohms.
    Time to buy a 3/8 NPT tap.
    Thanks for your help, where did you find those specs?
    Those ranges were for an 89 model LXi
    do you need say the ranges for 5th gen civic and 86 LXi?
    yep using the GM sensors may solve that, specs from Snap on Vantage
    bobafett's Avatar
    Longview, WA
    86 lxi specs would help if they differ at all. However even if they are different I suspect that they will not be close enough to allow me to use the stock sensors.
    bobafett's Avatar
    Longview, WA
    Here is the chart for the GM sensors.
    Code:
    Temp, C | Temp, F | Resistance, ohms
    -40        -40            100700
    -18         0              25000
    -7         19              13500
    4          39               7500
    20         68               3400
    38        100               1800
    70        158                450
    100       212                185
    110       230                133
    120       248                102
    140       284                 62
    the 92-95 Civic and 86 LXi are the same values !
    bobafett's Avatar
    Longview, WA
    Good to know, thanks!
    those GM values posted are for the ECT , the IAT are different
    bobafett's Avatar
    Longview, WA
    hmm, what values do you show?
    I am looking in the following PDF:
    http://distributorless.com/products/tecgt.php
    http://electromotive-inc.com/pdf_fil...rs%20Guide.pdf
    Page 93-95 (PDF pages 94-96)
    They claim to use 3/8 NPT threaded 'GM Style' sensors. I suppose it is possible that their sensors are calibrated differently, but I do not see any advantage to doing this. It looks like a similar sensor body with different colored connector and a different material in the tip.
    Either way it sounds like I will need to use their sensors as opposed to making the Honda stuff work.
    Page 96, shows IAT GM 70F-3300 ohm then 180F-350 ohm
    those not quite the same, but then I am wondering why they didn't go lower temp and why so high temp as 180F, that is some hot intake air... ahhh turbo
    Maybe I read it wrong
    Vantage says GM IAT res parameter are:
    40F- 7500ohm
    70F- 3400 ohm
    100F- 1800 ohm
    160F- 450 ohm
  1. Cooling fan resistance?
    By hondaaccorddrew in forum 3geez Accords
    Last Post: 07-06-2012, 11:51 AM
  2. wind resistance
    By 89lxisedan in forum Classic Honda Community Chat
    Last Post: 07-06-2009, 08:57 PM
  3. anyone got torque/hp curves?
    By johnwc723 in forum Performance
    Last Post: 01-31-2004, 10:46 PM
  4. Anyone know what the ignition wire resistance should be?
    By Hash_man_Se_i in forum 3geez Accords
    Last Post: 10-19-2003, 06:14 PM
  5. Lower resistance = more power?
    By pimp86LX in forum Interior & Exterior Care
    Last Post: 04-06-2003, 08:19 AM
