Results 1 to 13 of 13
Thread: car won't start
    bridgewater.NS Canada
    Exclamation car won't start
    well i tried to srart the black 88 today,it's been sitting all winter.hopefully it starts to warm up soon so i can work on it.i charged the battery but no start,all it did was click.i tried to jump it on the solenoid and all i heard was a click,sounded like it came from inside car.is it the main relay or the starter.i can hear the fuel pump when i turn on the key.it worked before the winter so i don't know whats wrong with it now.any ideas guys.
    Re: car won't start
    come on guys doesn't anyone have any ideas.it ran fine before the winter and now it won't roll.
    Re: car won't start
    Check the battery clamps, make sure they are making good connection and are secure.
    Exclamation Re: car won't start
    battery terminals seem ok but to cold out to check connections.
    LXi User coope's Avatar
    Sep 2006
    89 accord lxi efi
    mississippi
    Re: car won't start
    check the main relay take it out and see if the connectoins are lose u should have crunk it at lest once a week during the winter since u negleted it now its returning the favor pray to 3geezus for forgivness lol
    Re: car won't start
    took out main relay and soldered it didn't make any difference.i think something maybe froze up. i'll wait til it warms up and try again.picked up four 195/50/15 tires today for it for120.00,but i think one has the belt broke,the tread looks wavy on the outside tread.might have to get another one.
    Re: car won't start
    amazing you can resolder the main relay, some money saved there
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: car won't start
    Have you tried seeing if if would turn by the crankshaft? i wouldn't go gung ho on it but if it moves like normal i'd swap starters if the grounds check out. hook up an extra ground see if that does it? good luck man
    Re: car won't start
    it's grounded to the motor and the frame already.
    LX User GraniteLXI's Avatar
    Sturgeon Bay, WI
    Re: car won't start
    Sounds like a dead battery or starter....my 3gee did the same thing when i went to try and start it to find that the battery was dead after sitting for 4 months (big surprise there lol) just clickclickclickclick noise really fast, i charged my battery for 20 mins, 3 cranks and she fired up without a hiccup. To me it sounds like a starter problem because my starter was acting the same way when it was getting insufficient electricity... worked fine after i charged my battery up tho. I wonder if something seized in your starter from sitting somehow... dunno I started my 3gee about once every 3 or 4 months during the snow season and let it warm up in the garage. Did you run your 3gee at all during the winter as I did?
    Re: car won't start
    no it was covered with a tarp so it would have ment taking that off every time to start it.
    Re: car won't start
    ok so it's warmer out today so i deside to change my starter .get that done and try to start her,no go and now my tach goes up when i tryto start it.why does it do this,anybody know?
    Re: car won't start
    ok took bat out of my car and put it in and the car srarts guess it was just the bat .but the starter is change,the solenoid had a loose bolt anyway so i guess it's a good thing i changed it.
  1. hot car won't start
    By snoopyloopy in forum EFI Tech
    Last Post: 02-23-2010, 09:37 PM
  2. 86 accord start then died then wont start again
    By khmerproduction in forum 3geez Accords
    Last Post: 02-03-2006, 08:07 AM
  3. Won't Start...
    By pthump in forum Carburetor Tech
    Last Post: 05-28-2004, 05:03 PM
  4. Replies: 4
    Last Post: 12-30-2003, 10:45 AM
  5. Won't Start
    By infecto in forum 3geez Accords
    Last Post: 04-25-2003, 11:53 PM
