well i finally got the accord running with the new weber on it and fresh cylinder head. i set the timing just about as good as i can get it. also i've set the fuel as far as it will go. i think its not getting enough fuel. i havent replaced the fuel pump, it is after market but not beyond an OEM pump. i'll tell you what its doing. it'll idle ok, but slightly lumpy. when i give it WOT it boggs and doesnt want to rev up unless the throttal is somewhat gradually opened fully instead of all at one time. i dont think it is, but it may be the timing. but i do need to put a higher volume fuel pump.
i'd like a fuel pump that is going to flow more volume and not starve the carb at high rpms. i already have a fuel pressure regulator on it, that maxes out at 5.5 psi of fuel pressure. maybe this carb needs a bit more?
