Results 1 to 7 of 7
Thread: Annoying Vibration
    Nov 2006
    Annoying Vibration
    My car is constantly vibrating when I'm sitting at idle and I feel like this affects my car on top of this being very annoying. I have noticed it idles at 1200 and it starts virbrating harshly. I also have noticed that when I have my lights on, the dashboard goes extremly dim. Also when I turn on things in the car like my heat, this induces the vibrating even more. What is wrong with my car. Can anyone help me?
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Annoying Vibration
    Unless your sittin on solid mounts that sounds like a very bad thing.
    how many miles on it? recently developed this problem or did something happen
    Nov 2006
    i have 68 k on it, but i have had so many problems with it i feel like the milage doesent matter what things are wrong with the car, today i went to go look at the idle its actually not 1200 its 500. also this only occurs when the car is in drive, when i put the car in neutral or park, the idle bumps up and the vibrating goes away, can you help me? whats wrong with my car?
    Nov 2006
    Apr 2007
    1988 Accord LX 5spd
    The idle speed will effect the altenator output therefore the lights will be dimmer.Check the rpm at idle and with the lights and heater on full.
    Then check again in gear. Compare them both and see if rpms are within spec.
    500 is really low, the only time mine ever idles that low is when it has just been started and put in gear but not revved a little, I'm not sure, but is it carb'd? If so that may need some adjustment. Also theres a rolling knob on the dash on your right hand side to adjust the gauge brightness (I always keep it at full, and doesn't cause any problems or excessive battery drain) so maybe check that.
    EDIT: doh, carb section haha
    Your vibrations and low voltage(dimming) is caused by such low idle. Idle should be set at around 1,000rpm for automatic, possibly even higher. This is so that when the car is placed into drive or any gear, the rpms will drop but will not drop far enough such as 500rpm. Lowest lowest that the sticker under the hood says is 750rpm's. You need to raise the idle speed.
  1. Annoying front end vibration
    By VIPER1988 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-20-2010, 09:29 AM
  2. car audio is by far the most annoying thing ever
    By 89accordLXiAllAudio in forum Interior & Exterior Care
    Last Post: 10-27-2003, 10:56 PM
  3. my car is annoying in the morning
    By chanyeehon in forum Carburetor Tech
    Last Post: 10-23-2003, 07:05 PM
  4. very annoying sound
    By BLck89accord in forum 3geez Accords
    Last Post: 02-15-2003, 07:22 PM
  5. Annoying Beeping
    By SteveDX89 in forum 3geez Accords
    Last Post: 06-03-2002, 06:32 PM
