Results 1 to 5 of 5
Thread: washer trick
    LX User 89sei89dx's Avatar
    Mar 2007
    87 hatch lxi
    yakima wa
    washer trick
    i lowered my car and i want to fix the camber. i found alot of 84 87 preludes in the j.y. but i dont understand how to do the washer trick on the rear suspension. can anyone show me pics of this . or give me a link for where it goes into better detail. i searched also but found many posts that said something about . but not detailed
    Re: washer trick
    my camber in the back is not that bad....but where the upper control arm is unbolt it from the body and just add washer to it...and it might be recommended to get a longer bolt...the more washers you put on it the more you will get positive camber as it pushes the ball joint further out
    LXi User EX-ileAccord's Avatar
    Feb 2005
    89 accord EX-i 88 accord hatch s
    NS, Canada
    Re: washer trick
    I bought after market rear upper arms a wile ago, and there adjustable. They look just like the ones I put in my friends civic, out of some camber kit he ordered only difference I payed way less lol. I got them at the local napa dealer, I think there moog. There around here some where I'll have a look and post some pics.
    Re: washer trick
    the two "legs" that hold it to the car need to be spaced slightly outwards for the prelude arms to go in. Take out the long horizontal bolt that goes through the arm and put 1 or 2 matching washers inbetween the "legs" and the bushings. You will need to use the longer accord bolt.
    Eric
    Re: washer trick
    Quote Originally Posted by POS carb View Post
    i did that...but the washers make noise....i was in a rush to get my car rolling so i forgot to lube them up.
  1. egr trick
    By pickupman6 in forum EFI Tech
    Last Post: 01-09-2012, 06:32 PM
  2. The Allegded washer trick
    By bank2me in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-01-2008, 07:55 AM
  3. Washer trick for camber correction
    By Mattphi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-12-2004, 03:34 AM
  4. Washer Trick??????
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-25-2004, 12:40 AM
  5. Car always Hot? Hes a lil trick
    By Guyver007 in forum 3geez Accords
    Last Post: 07-28-2002, 12:55 AM
